Sykes Pickavant Acr2 Communication Trouble
9 replies to this topic
#1 kommander
kommander
  • 210 posts
Posted 09 February 2013 - 05:52 PM
Recently bought a Sykes Pickavant ACR 2 to use on my MIni SPi.
Connected the harness and using the Rover 3 pod.
I get a message stating 'unable to establish communication'.
I have followed the instructions in the manual, as well as double checked all connections and wiring!
Has anyone encountered this problem? Please point me in the right direction!
The car works fine, so doubt it may be the ECU!
#2 hunterg30
hunterg30
  • 349 posts
Posted 09 February 2013 - 11:05 PM
have you plugged it into the right socket,there are two near master cylinders, one green the other white . you need to use the white one
#3 kommander
kommander
  • 210 posts
Posted 10 February 2013 - 01:00 PM
Yes, my car doesnt come with the alarm, so yes it's connected to the white one with the black cover!
#4 dreadster
dreadster
  • 139 posts
Posted 10 February 2013 - 02:44 PM
Wish I had seen this before posting on the code reader thread. I'm having the same issues but I have been using the green connector...
Back to the garage to try again!
#5 dreadster
dreadster
  • 139 posts
*double post
Edited by dreadster, 10 February 2013 - 02:45 PM.
#6 Manuel B
Manuel B
  • 46 posts
  • Local Club: BAMA, Mini's United,
Posted 11 February 2013 - 08:24 PM
Ignition turned on ? I get that message if the key is not turned on.
#7 kommander
kommander
  • 210 posts
Posted 13 February 2013 - 06:34 PM
yes the ignition is turned on! as I said, I am following the instructions in the manual!
#8 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 15 February 2013 - 12:32 AM
Which pod are you using?
#9 70aarunner
70aarunner
    Starting My Mini Up
  • 3 posts
Posted 16 February 2013 - 07:46 AM
Try hooking your 12V power cable directly to the battery instead of the starter. My Crypton ACT wouldn't communicate until it powered directly from the battery. Something to try.
#10 kommander
kommander
  • 210 posts
Posted 17 February 2013 - 01:33 PM
OK folks, got the reader to work.
Apparently the option I was using was the problem. Strange enough I had to select MEMS 1.6 (<95) for it to work!
