Water In Driver And Passenger Footwell.
12 replies to this topic
#1 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 08 February 2013 - 07:42 PM
As title I was just wondering if people had any ideas on where it might becoming from before I start dismantling thanks Jack
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 08 February 2013 - 07:45 PM
a door of window rubber
a hose pipe and a mate should make finding the leak easy
#3 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 08 February 2013 - 07:52 PM
Alright looks like ill do a full strip then
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 08 February 2013 - 07:55 PM
just remove the carpets, you don't need a full strip
#5 malynch27
malynch27
  • 114 posts
Posted 08 February 2013 - 07:58 PM
What about checking the pipes into the heater. The matrix might have sprung a leak. Just runu your hand around the bottom of the heater.
Good luck fella
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 08 February 2013 - 08:01 PM
that normally leaves you with coloured water in the foot well and a hot car
#7 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 08 February 2013 - 08:11 PM
Door seals are probably the most common culprits, so first have a close inspection of both door seals for cuts, tears, perishing and signs of wear etc. If you see any signs of damage, then you'll have some idea of where to aim the hosepipe to check for leaks. Other common places are the windscreen seal, the heater matrix & hoses and the often overlooked door check strap seals. These foam seals are notorious for perishing, getting damaged by the door check strap or even just being missing completely and therefore letting rain water in.
#8 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 08 February 2013 - 09:24 PM
The leak was there before the heater hoses were connected I have no door straps so no seals there are cuts in the door seals I think it is coming from behind the dash area as its drains down the interior arch bit I have checked the windscreen seal it seems okay
Thanks Jack
#9 jakejakejake1
jakejakejake1
  • 644 posts
Posted 08 February 2013 - 09:49 PM
I have a similar issue, I can sometimes see droplets of water on the inner arch/footwell area, below where the heater inlet pipe go thorugh - but on the passenger side if that makes sense
#10 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,038 posts
  • Name: Neil
Posted 08 February 2013 - 09:52 PM
It could be rust around the fresh air vents. A common area for rust.
#11 Nathan86Mayfair
Nathan86Mayfair
  • 49 posts
Posted 08 February 2013 - 10:05 PM
The heater matrix and pipes, rust under the front window, doors or sunroof.
#12 Samwise777
Samwise777
  • 221 posts
Posted 08 February 2013 - 10:14 PM
I had this problem year- was partially windscreen seal that needed replacing but actually found a tiny hole in my o/s floor plan just behind the wheel so water ended up flicking up from the road :/
#13 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 08 February 2013 - 10:29 PM
Ah okay ill try it with a hose see how far that gets me thanks again for the help guys
Jack
