Huy'e Clubby Estate '78
289 replies to this topic
#121 minimuk
minimuk
  • 1,947 posts
Posted 18 May 2013 - 12:45 PM
and so the repair carries on, found a hole underneath some tar-ish paint in the OS arch,just were the side valance and arch extension meets, same on the NS, so start again;
cut out rot and cleaned "paint" away;
Attached File  wheel arch repair 2.jpg   94.92K   15 downloads
made a template from the hole and side valance and shaped the new steel to position, so many light corners in that piece;
Attached File  wheel arch repair 3.jpg   89.39K   14 downloads
after a lot of fettling, drilled holes for plug welds, and treated the back of the panel with Por15, and the inside of the floor beam, welded the lot and sanded it back, ready for seam sealer and paint;
Attached File  wheel arch repair 4.jpg   95.87K   18 downloads
scraped all the tar-ish paint of the arch and clean it with paraffin at some time before paint get's near it, this will be after the other side of the arch has been done including the bottom quarter repair :goaway:
#122 minimuk
minimuk
  • 1,947 posts
Posted 19 May 2013 - 12:36 PM
and here I started the other side.......
pictures tell the story so-far;
Attached File  wheel arch NS repair 1.jpg   83.7K   13 downloads
Attached File  wheel arch NS repair 5.jpg   96.24K   11 downloadsAttached File  wheel arch NS repair 6.jpg   119.21K   16 downloads
waiting for paint to dry :goaway:
#123 minimuk
minimuk
  • 1,947 posts
Posted 19 May 2013 - 05:23 PM
after a few hours strimming in the garden,...... the paint is dry-ish...., back on with it
Attached File  wheel arch NS repair 7.jpg   38.78K   5 downloadsAttached File  wheel arch NS repair 8.jpg   30.84K   9 downloadsAttached File  wheel arch NS repair 9.jpg   35.81K   10 downloads
seamsealed underneath, another job done.... ;D
#124 minbin 69
minbin 69
  • 465 posts
Posted 19 May 2013 - 05:59 PM
looking good muk..you'll soon be done at this rate :)
#125 minimuk
minimuk
  • 1,947 posts
Posted 20 May 2013 - 02:27 PM
cheers Minibin69, it's when you have a good run , make the most of it......
this morning,
I filled and sanded back the NS rear Quarter repair and sprayed it with etch primer;
Attached File  wheel arch NS repair 10.jpg   24.75K   9 downloads
 then back to the OS Rear Arch and quarter repair;
Attached File  wheel arch repair 6.jpg   100.04K   6 downloads
inside companion bin;
Attached File  wheel arch repair 8.jpg   112.2K   9 downloads
glad this arch repair is done, amazing what you find underneath tar-paint........ ;D
thank you for watching
#126 minimuk
minimuk
  • 1,947 posts
Posted 21 May 2013 - 04:28 PM
good day on the rear quarter repair;
fabricating panels and tacked them on
after welding and sanding back filler went on
sanded back filler with 80-120-240-600
refill the few pinhead holes
Attached File  wheel arch repair 12.jpg   98.76K   5 downloads
sanded back and etch primed the lot again
Attached File  wheel arch repair 13.jpg   96.4K   6 downloads
happy with progress, even managed to get the sliding window out for new gliders.......and cleaned the NS arch of the tar paint and repainted it with Por15
Edited by minimuk, 22 May 2013 - 04:23 PM.
#127 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 07:37 PM
Great work as always,  a good repair looks good in etch primer !!
#128 minimuk
minimuk
  • 1,947 posts
Posted 23 May 2013 - 10:33 PM
Thanks Graham, I am doing my best, few more welding bits to do and start painting,....ohh yes and engine to do still.....
#129 minimuk
minimuk
  • 1,947 posts
Posted 25 May 2013 - 10:49 PM
had a little time this afternoon and after work tonight, gave the floor above rear subby first topcoat.....
Attached File  first topcoat floor 1.jpg   92.95K   12 downloadsAttached File  first topcoat floor 2.jpg   85.96K   3 downloadsAttached File  first topcoat floor 3.jpg   23.29K   6 downloadsAttached File  first topcoat floor 4.jpg   23.6K   2 downloads
and sanded and painted the side window frames, ready for new channels ;D
#130 minbin 69
minbin 69
  • 465 posts
Posted 25 May 2013 - 11:12 PM
looking good as always muk..must be nice to be finally getting colour on...
#131 minimuk
minimuk
  • 1,947 posts
Posted 26 May 2013 - 12:26 AM
yep indeed, makes you feel yr just passed the half-way line, still a few hurdles waiting for me tough :proud:
#132 minimuk
minimuk
  • 1,947 posts
Posted 28 May 2013 - 04:44 PM
Today OS heal board repair done, and dropped the outer sill, glad I did, few pin holes near companion bin and large holes near the cross-member end other than that the inner-sill and floors are sound.
pinholes;
Attached File  OS outer sill repair 1.jpg   107.28K   11 downloads
Cross-member holes cut out;
cut out rot, replaced and Por15 coat;
Made repair piece for cross-member holes,
dropped tools and went to see "fast and furious 6"
welding  on Huy'e is coming to the end,.........might trow in a roll-cage though.... ;D
#133 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 28 May 2013 - 04:57 PM
looks good, When do you hope to have it on the road.
#134 minimuk
minimuk
  • 1,947 posts
Posted 28 May 2013 - 05:00 PM
He has to be on the road for the MITP,so 2 month to go.........that's the plan :shades:
#135 alex-95
alex-95
  • 6,078 posts
Posted 28 May 2013 - 05:03 PM
not that long, but long enough ;D, Much else to do other than the welding?
