Huy'e Clubby Estate '78
289 replies to this topic
#106 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 06 May 2013 - 08:35 PM
Coming along nicely :D
#107 minimuk
minimuk
  • 1,946 posts
Posted 07 May 2013 - 03:30 PM
Gave the subby another coat of Por15 then dropped old tank , , and numberplate back plate and lights...they were in need of clean and paint
Attached File  tank 3.jpg   78.91K   7 downloads
take bumpers of and get the boot floor underneath a good clean and a few bits of welding before some coats of paint
#108 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 07 May 2013 - 03:34 PM
Good luck with the tank!!
#109 minimuk
minimuk
  • 1,946 posts
Posted 07 May 2013 - 04:25 PM
I am confident enough now, you warned me with all, it does help having the subby of though, we bit valence repair and pop it back on again,......next week.....
#110 minimuk
minimuk
  • 1,946 posts
Posted 13 May 2013 - 09:03 PM
not much done today but managed to get one of the radius arms cleaned and painted, tomorrow the other one and a lot of welding under the boot floor hopefully ....
fettling on....
#111 minimuk
minimuk
  • 1,946 posts
Posted 14 May 2013 - 07:40 PM
started with the under-boot floor cleaning and stripping of "paint"cut out rot in valance and prepped for repair, overall for a 1987 it is in good condition, and only need 1 more panel repair under rear seat.
heal-board B4 stripping
after strippng
Por15 treat
Attached File  off side por 15.jpg   105.15K   7 downloads
second coat por15 on thursday after a few bit's of welding ;D
#112 minimuk
minimuk
  • 1,946 posts
Posted 15 May 2013 - 08:24 PM
second coat is on.........one day early ;D
Attached File  second coat Por15 1.jpg   93.53K   13 downloads
Attached File  second coat Por15 2.jpg   90.94K   11 downloads
scot-brite and 1st topcoat tmz
#113 minbin 69
minbin 69
  • 465 posts
Posted 15 May 2013 - 08:56 PM
nice project you've got there..keep up the good work
#114 minimuk
minimuk
  • 1,946 posts
Posted 16 May 2013 - 04:33 PM
cheers minibin 69, half the job then you have at the moment, Like your courage ;D
#115 minimuk
minimuk
  • 1,946 posts
Posted 16 May 2013 - 04:39 PM
good day in the garage this afternoon, repaired inside and outside valance panel and patched the rear seat, and seam sealed the lot,
a bit of Por15 later when dry and then stone-chipping tmz,.....Shifty I think you need to put your skates on soon.......
inside valance;
outside valance;
rear seat;
Attached File  rear seat repair 1.jpg   74.78K   8 downloads
Happy with progress  :gimme:
thank you for yr interest,comments are welcome........
Edited by minimuk, 16 May 2013 - 04:40 PM.
#116 minbin 69
minbin 69
  • 465 posts
Posted 16 May 2013 - 04:41 PM
thanks...thinking it's more stupitiy on my part :lol:
but i've started it now so gotta do something with it >_<
#117 minimuk
minimuk
  • 1,946 posts
Posted 16 May 2013 - 04:46 PM
 nah, yr ok, yr not the only mad one,...... I am doing the same with "Total Rebuild Of '71 Evy "
#118 minbin 69
minbin 69
  • 465 posts
Posted 16 May 2013 - 04:54 PM
it's the mini mentality :lol:
just about to go check that one out..
#119 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 17 May 2013 - 11:56 AM
I'm at the point where I'm nearly thinking about getting back in the garage!!
(nice work though!!)
#120 minimuk
minimuk
  • 1,946 posts
Posted 17 May 2013 - 04:18 PM
today, both radious arms done and new cylinders in, stone cipped the underside of the bootfloor and started on the lower arch repair.
underside boot floor
 I sanded back the arch repair, what a mess the white powder makes, on the bottom corner is a rusty hole, thats not all but a piece of panel is wedged on the inside and then someone had the bight idea to fill the hole from the outside, what a waste of time.....ohh yes and I found an arch rivet hidden behind the plaster with a rusty surround,.........this repair will be a slight set back of 1 day
Attached File  wheel arch repair 1.jpg   66.8K   6 downloads
and yes Shifty start going back into yr garage....... ;D
