Huy'e Clubby Estate '78
#91
Posted 25 April 2013 - 04:32 PM
#92
Posted 25 April 2013 - 05:03 PM
looking nice. i bet your glad the welding is out the way?
Cheers Tom, not done yet though, healpanel floor repairs next then new sill's, after that.....maybe....
#93
Posted 25 April 2013 - 05:36 PM
#94
Posted 25 April 2013 - 06:03 PM
Looks good minimuk.
cheers Alex, hows your mini....
#95
Posted 25 April 2013 - 08:48 PM
Not to bad, The ritz need's a bit more work for a MoT, front passengers wheel bearings and ball joints, disc pads and more, But don't have long to get it done for the riviera run (5th may). I haven't done anything to mine for a while.
Looks good minimuk.
#96
Posted 25 April 2013 - 08:59 PM
Looks good minimuk.
Is that the run in Newquay? still got a week to get him ready...good luck
#97
Posted 25 April 2013 - 09:26 PM
Yeah, Only a couple of days working on it
Looks good minimuk.
#98
Posted 29 April 2013 - 04:26 PM
slow progress but it is progress, nearside inner-sill patch repair near heal-board
this was repaired before by just another plate placed on top of the old rotten piece, why ohh why does one do that....
cut out the 2 layers and cleaned it off
welded in a new panel piece,
then I had to walk away from it,
need to fabricate a stiffener/bracket for the heal-board mounting plate to replace the old one, this also will strengthen the outer sill in that corner.
having fun indeed
#99
Posted 30 April 2013 - 01:26 PM
good morning bash today,
rear quarter bottom repair;
cut out,...weld on repair piece...,filler on,...filler sanded with 80-240-400, etch primer on......
nearside sill repair rear quarter 5.jpg 119.84K
8 downloads
carried on with inner/outer sill stuff, coated inner sill area and inside companion bin with por15 last night;
nearside sill repair 3.jpg 100.73K
12 downloads
prepared outer sill and painted inner and outer sill before welding in place tmz;
nearside sill repair 4.jpg 128.79K
15 downloads
happy with progress today, offside next week.......unless I can fit in a few hours here and there this week....
thanks for looking
Edited by minimuk, 30 April 2013 - 01:52 PM.
#100
Posted 01 May 2013 - 03:24 PM
as promised, outer sill on, .......
after a good soaking of wax-oil especially in the cavities. I spot-welded the doorstep/sill lip;
nearside sill repair 5.jpg 112.15K
9 downloads
and plug welded underneath, got a haircut for free....
nearside sill repair 6.jpg 95.42K
21 downloads
hopefully I have an hour tmz to clean up the welds and do a few seam welds between the flutes and near heal board
Edited by minimuk, 01 May 2013 - 11:40 PM.
#101
Posted 03 May 2013 - 04:06 PM
had a few hours today, upside down welding is great fun.......anyhow the sill is on, sanded back and primed, then first coat of paint.Seam sealing tmz and final coat of paint. Getting there.....
nearside sill repair rear quarter 6.jpg 100.55K
9 downloads
nearside sill repair rear quarter 7.jpg 99.11K
10 downloads
starting other side soon.....
thanks for looking
#102
Posted 03 May 2013 - 04:17 PM
Looking good!!!
#103
Posted 03 May 2013 - 04:51 PM
Looking good!!!
Sean, one step at the time... now way ready for Himley, but looking towards MITP......
#104
Posted 05 May 2013 - 06:21 PM
just checking the Off-Side,sill repairs......the old repairs....... needless to say, hands full again, I will have to drop the subframe to tidy the lot after....
bit of ...repair gone bad after years standing in damp conditions
#105
Posted 06 May 2013 - 08:32 PM
Bank oliday........first work from 7-2Pm, got home and sneak t into the garage,........I was going in to asses the next job, ended up dropping the rear subby and taking that apart radius arms need a bit tlc, but work fine, hub needs a refurb but I might have a few laying somewhere subby looked ok from underneath but on top, under boot floor is had surface rust.......10 minutes elbow grease and wire brush and al came off, then gave it the first cot of Por15 to keep the virus away......then it was BBQ time
previous repair gone bad;
subby pre por15
subby after por15
with the subframe removed I do have better access to the tank, sorry Shifty but the tank will come of shortly too
Edited by minimuk, 22 June 2013 - 12:04 AM.
