Huy'e Clubby Estate '78
289 replies to this topic
#76 minimuk
minimuk
  • 1,946 posts
Posted 15 April 2013 - 01:12 PM
Finally now the late winter has gone, back in the garage, 3 weeks ago it was that cold I could noty weld nout, so here we are back to thescript, 2 month to go..........
welded NS floorpanel repair piece in position, sanded back the welds cleared all the old paint and por15 the lot;
Attached File  nearside floor panel repair 5.jpg   37.2K   7 downloads
then there was the flitch bottum corner repair, patch in innersill (near crossmember) and doorstep, sanded and por15;
Attached File  nearside floor panel repair 7.jpg   100.13K   10 downloads
tmz flitch end to door/stiffener and hinge panel,..then back with the wing and scuttle end........perhaps
Edited by minimuk, 15 April 2013 - 03:23 PM.
#77 minimuk
minimuk
  • 1,946 posts
Posted 16 April 2013 - 12:11 PM
good morning in the garage today, scuttle end on and hinge repair panel offered and Por15 the lot;
scuttle;
Attached File  nearside scuttle repair 6.jpg   114.93K   4 downloads Attached File  nearside scuttle repair 7.jpg   121.11K   8 downloads
hinge panel;
Attached File  hinge repair panel 1.jpg   101.69K   11 downloads Attached File  hinge repair panel 2.jpg   105.86K   8 downloads
por15;
Attached File  hinge repair panel 3.jpg   89.43K   17 downloads
and so it goes on, cleaning the outerwing tmz
#78 minimuk
minimuk
  • 1,946 posts
Posted 17 April 2013 - 06:41 AM
after ruffing up the Por15 sprayed with etch primer, need seam sealing and a little filler on edge of scuttle, other then that, happy with progress
Attached File  nearside scuttle repair 8.jpg   85.31K   7 downloads Attached File  hinge repair nd scuttle panel 4.jpg   130.38K   14 downloads
wing cleaning this afternoon
#79 minimuk
minimuk
  • 1,946 posts
Posted 22 April 2013 - 02:59 PM
this is going slow, then again it is the wing's nightmare........
trial fitting day today;
door b post
Attached File  wing door and a-panel 3.jpg   131.15K   9 downloads
a-panel to door gap
wing,scuttle and a-panel
after 2 hours fettling, time to leave it alone, few small welding jobs done for the final fit, hopefully tmz
thank you for looking ;D
#80 ToM 2012
ToM 2012
  • 4,066 posts
Posted 22 April 2013 - 04:32 PM
looking good mate. what is that por15 stuff? as i will have to do loads of welding on my mini and do you recommend using it?
#81 minimuk
minimuk
  • 1,946 posts
Posted 22 April 2013 - 07:29 PM
Tom hi, Por15 is a product, that seals older cleaned panels(new ones to if you key them first) and prevents anything to go through as in petrol, acids etc, Por15 wont crack and still in a way a little flexy, check out Frost Uk.
I like working with it and use it instead of priming first then red oxide, the another coat the topcoat, it is what you prefer I guess,I believe in this stuff to keep the virus out or from returning.... ;D
#82 ToM 2012
ToM 2012
  • 4,066 posts
Posted 22 April 2013 - 07:35 PM
so you put this onto the metal then primer then paint? and dont you use stone chip? and how much do you pay for it? do you apply with brush or spray on? cheers tom
#83 minimuk
minimuk
  • 1,946 posts
Posted 22 April 2013 - 07:42 PM
start with paint-free ish metal, Por15 then key with scotchbrite, primer or etc-primer pending where you are working on, under body (BELLY) and non visable areas few layers of stone chip then paint with whatever finish.
Por15 is brush-able only, don't get it on your skin,pain in the back to get it off just like tattoo ink, not cheap but what good stuff isn't.
#84 ToM 2012
ToM 2012
  • 4,066 posts
Posted 22 April 2013 - 07:46 PM
cheers mate will defo get some for when i start the metal work. cheers :-)
#85 minimuk
minimuk
  • 1,946 posts
Posted 22 April 2013 - 07:54 PM
good luck, check out Frost UK first, they are the sole importers, they advise various stages and metal prep sprays before applying Por15, the only one I sometimes use is "metalprep"(kinda accid) to give the complete paint-free panel a final clean and starting to oxidise, that's the time when Por15 works at it's best....
#86 ToM 2012
ToM 2012
  • 4,066 posts
Posted 22 April 2013 - 07:59 PM
how much do you pay for it? and will look into it. how much would you rekon on buying to completly do the floor are outside and inside.
#87 minimuk
minimuk
  • 1,946 posts
Posted 22 April 2013 - 08:19 PM
never had to do that as yet but 1 tin of 475ml does the belly, sill area boot floor and arches that cost about 27quid inc postage, you buy 930ml for £33 +postage so a whole car inside and out my guess is £135 approx
#88 ToM 2012
ToM 2012
  • 4,066 posts
Posted 22 April 2013 - 08:26 PM
cheers mate will get some when i start.
#89 minimuk
minimuk
  • 1,946 posts
Posted 23 April 2013 - 03:07 PM
great day today, lots of progress
started with a few outstanding repairs, as in inner-wing gutter flange at the back needed replacing, scuttle end closure plate,needed put in place, and yes nearly forgot, 1 vent mounting hole and nut needed drilling and welding in position, from then on it was all go.
scuttle closure plate and vent nut in
Attached File  wing door and a-panel 4.jpg   80.9K   8 downloads
final fit before welding
Attached File  wing door and a-panel 5.jpg   84.59K   6 downloads
tacked top and bottom of a-panel and plug welded wing in gutter
Attached File  wing door and a-panel 5a.jpg   19.77K   8 downloads
used (Shifty's) spot welder to join the wing and a-panel flanges, bend a-panel flange around the flitch flange in doorpost and then quick spray with etch primer(will come of tmz for Por15 coat)
Attached File  wing door and a-panel 7.jpg   102.08K   7 downloads
few pictures of the bonnet-wing gaps. All in all a good day, well happy
Attached File  wing door and a-panel 8.jpg   14.9K   6 downloads
thanks for looking ;D
Edited by minimuk, 23 April 2013 - 07:26 PM.
#90 minimuk
minimuk
  • 1,946 posts
Posted 25 April 2013 - 04:15 PM
finished the welding, sanded all back and gave it a nice coat Por15
scotch-brite wings and front panel tmz followed by etch primer
