Huy'e Clubby Estate '78
289 replies to this topic
#271 Zara
Zara
    BANANAS!
  • 263 posts
  • Local Club: Charnwood Minis
Posted 10 April 2014 - 04:11 PM
Best thing I did was convert to springs and hi los. Never looked back since.. nice work dude :)
#272 minimuk
minimuk
  • 1,946 posts
Posted 10 April 2014 - 08:11 PM
Cheers Zara, I always looked for a conversion to Springs but my wallet never agreed till Shifty found some on a mini and had my name on them....... then it was a must have....I believe the front ones are a pain to put on prob 1 hour each side with any luck, how's you by the way
#273 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 10 April 2014 - 09:01 PM
I thought I'd seen them before....
#274 minimuk
minimuk
  • 1,946 posts
Posted 28 April 2014 - 08:17 PM
bit of a to do with HUY's head....gasket gone in 3 places after 1000 miles. Then again he had a bitta pounding with the Weber 45 carb and various water issues........so I cleaned all de-choked head, lapped valve seats, taken the mayo out of the rocker cover, weighed a ton........waiting for new springs tmz and putting in a higher compression gasket......
Attached File  102_0229 a.jpg   143.03K   15 downloads
#275 stealth05
stealth05
  • 625 posts
Posted 29 April 2014 - 05:10 AM
not good ,
noticed you fit engine using brackets attached to head bolts , did you re torque the head after fitting i never use this method and put a strap around the whole engine / box ,could be a reason for early gasket failure ?
#276 minimuk
minimuk
  • 1,946 posts
Posted 29 April 2014 - 07:24 AM
not good ,
certainly could be a reason as I fitted the coil bracket after and did not re-torque that one enough, I might attache the bracket onto the bell housing instead this time....
#277 minimuk
minimuk
  • 1,946 posts
Posted 29 April 2014 - 04:12 PM
after a few hours fettling, replacing head gasket installing new valve springs etc, nd taking Stealth05 comment on board he is running nice.....this video is taken of his first start-up B4 timing/tuning
https://www.facebook...&type=2
give him a run laters.... ;D
#278 stealth05
stealth05
  • 625 posts
Posted 29 April 2014 - 06:57 PM
nice to see it up and running again mate , hopefully this time the head gasket will last a little longer   ;D did you fit a payen one or just standard  ?
Edited by stealth05, 29 April 2014 - 06:58 PM.
#279 minimuk
minimuk
  • 1,946 posts
Posted 29 April 2014 - 08:55 PM
yep still a bit fettling to get him smooth running, but he is running much better, yep hopefully this one will last.....
http://www.minispare...UG702560HG.aspx
#280 minimuk
minimuk
  • 1,946 posts
Posted 01 May 2014 - 02:43 PM
compression test done with a push on tester, Cylinder 1-4 148-170-170-170, Cylinder one has 1 old ring which explains the drop, over all happy with the result, engine was cold, if I had used a screw in tester the reading would have been better, compared with the old set-up it's overall an 20% increase ;D
#281 minimuk
minimuk
  • 1,946 posts
Posted 31 May 2014 - 09:09 PM
Su2 twin carb installed nd running
fine tuning fmz ;D
Edited by minimuk, 31 May 2014 - 09:11 PM.
#282 minimuk
minimuk
  • 1,946 posts
Posted 14 July 2014 - 07:07 PM
it has been a while, lot's of changes on the car sinds last post, but all good, got him ready for my 1000mile run/trip last week, new wheels and arches, looks the part for sure
Attached File  new boots 2.jpg   110.12K   9 downloads
shuttle journey to Calais, Morgan behind and Triumph all the boys toghether....
Attached File  new boots 3 shuttle.jpg   121.58K   10 downloads
nearly ready for IMM in a few weeks.... ;D
#283 minimuk
minimuk
  • 1,946 posts
Posted 21 October 2015 - 12:41 PM
Huiy'e has been doing very well as my daily for the last 22 month, his last trip was Stonley Hall,....now time has come to give him an engine re-ferb/upgrade, lightened flywheel, Evo 1 cam, duplex timing Chain, new LCB, new Piston rings...and whatever else I find on this journey....so will be fun for sure
Attached File  102_0655.jpg   125.43K   5 downloadsAttached File  102_0668.jpg   126.01K   4 downloads
#284 minimuk
minimuk
  • 1,946 posts
Posted 30 October 2015 - 12:05 AM
rebuild is getting on already, crank re-ground and fitted new bearings, thrust washers, idler gear and shims, new piston rings in, new oil pump, Evo 1 cam in, new Duplex on,......
Attached File  pistos.jpg   106.31K   2 downloadsAttached File  timing.jpg   111K   2 downloads
going well
#285 minimuk
minimuk
  • 1,946 posts
Posted 03 November 2015 - 11:19 PM
quick update, block and box back together, clutch sorted waiting for woodruff key to set the cam timing +2 degrees for me EVO1.....after that, new steering rack in sort zorst new LCB and drop the lmp back in.......
Attached File  block box.jpg   86.55K   1 downloadsAttached File  clutch.jpg   51.15K   1 downloads
1 more week.....
