Huy'e Clubby Estate '78
289 replies to this topic
#211 minimuk
minimuk
  • 1,947 posts
Posted 30 December 2013 - 12:07 AM
Good work mate
Cheers Alex, exhaust was a pain to get fitted, so I didn't as this one really fits a saloon rather then an estate, so ordered a Maniflow RC-40 for an Estate, hopefully is here on Tuesday......made a peddle box brake switch mounting plate  for my early peddle box so I can fit a brake light switch bracket for the switch, so in a nutshell, change from pressure brake light switch to electric brake light switch. Did't like to weld in the cabin again but had to be done.
#212 minimuk
minimuk
  • 1,947 posts
Posted 30 December 2013 - 11:03 PM
after a bit of effin and so, brake lights switch working and lights are on/off when need to.....chasing wires for an hour or so, current was all over the place, ended up to be the new fuse box with the old fuses in it, to much pay so not enough conduction, sorted that and all good. tmz new exhaust arrives,  Maniflow RC-40 will fit that one on the 2nd perhaps and do a tuning session on saturday/sunday.......getting close
#213 ToM 2012
ToM 2012
  • 4,066 posts
Posted 31 December 2013 - 08:29 AM
wow this is really nice! cant wait to see it at bingly hall mini show??
#214 Nossedout
Nossedout
  • 160 posts
Posted 31 December 2013 - 10:27 AM
by the way: goodluck with the build!!
Cheers, getting there.......I take it you have a clubby?
After searching high and low, i found a decent clubby estate... going to pick it up in a few weeks time!
i'm not going to cut it up and turning it into a pickup..:/ this one is a bit too nice to cut up.:)
#215 minimuk
minimuk
  • 1,947 posts
Posted 31 December 2013 - 10:43 PM
good luck with yr new project let us know when you start....
#216 minimuk
minimuk
  • 1,947 posts
Posted 31 December 2013 - 10:49 PM
had 1 hour this afternoon, attached brake light switch on peddle box and tested, put the steering column back together, RC40 arrived today and put him under all in position but a bit tweaking tmz for tight fit, then tuning starts.......getting close now ;D
Attached File  exhaust 1.jpg   58.2K   15 downloadsAttached File  exhaust 3jpg.jpg   57.2K   14 downloads
Happy new year to all
#217 minimuk
minimuk
  • 1,947 posts
Posted 31 December 2013 - 10:52 PM
That's the plan Tom.....MOT by the 15th hopefully
#218 minimuk
minimuk
  • 1,947 posts
Posted 01 January 2014 - 12:49 AM
Got back from work tonight 22.30.....kids are in their town's partying, wify is asleep, cat is out and about so yes I did go to the garage again and finished fitting the exhaust, all done at 23.56pm, just in time for a cuppa and watch the big ben banging away......
and now it is the 1st of January 2014, this must be a better year then 2013..........good luck
#219 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 01 January 2014 - 05:55 AM
how did the exhaust fit?
also looking to buy one this year but thinking about the maniflow with 2 boxes or the rc40 from minispares. but that is only a single box
freaker
#220 minimuk
minimuk
  • 1,947 posts
Posted 01 January 2014 - 01:58 PM
freaker
Hi Freaker, do you have an estate? if so this is the Maniflow code from MiniSpares;  C-ARA339   which is a twin box, I have an LCB with a Y-piece and fits no problem about 1 hour tops to sort it. Hope this helps
Edited by minimuk, 01 January 2014 - 01:58 PM.
#221 freaker
freaker
  • 1,378 posts
Posted 01 January 2014 - 08:39 PM
yes also have an estate,
will look into thanks :)
freaker
#222 minimuk
minimuk
  • 1,947 posts
Posted 01 January 2014 - 08:56 PM
veel geluk, met je mini
I will be taking Huy'e on his endurance test to Paris-Nurmburgh Ring-A'dam, same as Muk in october 2012, might come and say hello as you will be on the way back to the Tunnel
#223 minimuk
minimuk
  • 1,947 posts
Posted 02 January 2014 - 05:05 PM
Finally, one step closer to MOT,.....tuning session done, 55 min fettling and all is good, Idle at 1000, Co at 3.5,...timing at 12Btdc, cooling good all the lights working even the brake lights Simon
https://www.facebook...video_processed
another day....
#224 minimuk
minimuk
  • 1,947 posts
Posted 05 January 2014 - 08:24 PM
today I started on the interior, under felting and trim cards,.....stopped half way as the glue was making me high.....floors and off side rear seat trim and put 1 seat in to give him a go on the drive
Attached File  1596744_10152531821401040_1239641865_o.jpg   52.15K   8 downloadsAttached File  1266010_10152531823056040_1071444361_o.jpg   42.75K   12 downloads
Attached File  1556339_10152531823256040_526519123_o.jpg   42.92K   7 downloadsAttached File  1491519_10152531842756040_726949054_o.jpg   48.6K   7 downloads
Attached File  1537857_10152531843231040_207856730_o.jpg   42.75K   5 downloads
getting closer now, Bingley perhaps.......
Edited by minimuk, 05 January 2014 - 08:30 PM.
#225 minimuk
minimuk
  • 1,947 posts
Posted 06 January 2014 - 04:10 PM
After bit of fettling with door cards etc, 1 seat in....
Attached File  102_0259.JPG   49.76K   9 downloads
then I set the clutch lever, bled the clutch and.....engaged...few runs up and down the drive, happy sofar, adjusted the carb a bit and tried Dabs windscreen wipers...waw they work as it is pissin down....I found a small water leak on the water off-take to heater,now sorted,....other then that, carpets tmz and a few small bits ...number-plate.... good to go for MOT  ;D
