Huy'e Clubby Estate '78
289 replies to this topic
#196 minimuk
minimuk
  • 1,946 posts
Posted 26 November 2013 - 09:45 PM
Progress, today I got an engine crane, and put finally the lump in position,bolted in, put weber on, defo need to cut the bulkhead, easy done this week,make a box and set it back a bit, apart from that great to get passed this mile stone
engine in the air, first time it leaves the trolley
Attached File  engine off in the air.jpg   55.99K   14 downloads
nerve reckin
settled and bolted down
put his hat on
Weber side shot,...bulkhead needs defo cutting
good feeling this is and more space in the garage ;D
Going to put my Hif44 in instead of the Weber, I am not cutting t5he bulkhead.....so I
will be selling the Weber with all the extra's as this will be surpluss...
Edited by minimuk, 28 November 2013 - 01:25 PM.
#197 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 26 November 2013 - 09:53 PM
Very nice :gimme:
#198 minimuk
minimuk
  • 1,946 posts
Posted 08 December 2013 - 07:31 PM
although it looks like a stand-still,.....there is progress!!!!
rod-gear linkage cleaned, re-greased and put in position, gears are engaging, although a little stiff, that will just do me. Bled the clutch slave cylinder and master cylinder, all good no leaks. Further today used 'Track-ace' for wheel alignment on MUK and  the Golf Mk1, that took a bit of time but all done.
Tomorrow HUYe will get some attention,... I will put the re-con drive shafts in and will do the alignment on him, might even do the exhaust....
Piccies soon
#199 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 08 December 2013 - 07:37 PM
its not a bad tool is it?
#200 minimuk
minimuk
  • 1,946 posts
Posted 08 December 2013 - 09:13 PM
Excellent tool you lend me,....getting the hang of it after 2 cars.......will check the camber again tmz................
#201 minimuk
minimuk
  • 1,946 posts
Posted 09 December 2013 - 08:48 PM
drive shafts done, front suspension lowered and wheel alignment done, tmz weber 45 and exhaust.......getting somewhere..... ;D
#202 minimuk
minimuk
  • 1,946 posts
Posted 10 December 2013 - 05:18 PM
few jobs done today, front engine steady is in, and put the LCB in,  unfortunately the weber ain't fitting wiv filter on either unless I make a bulkhead cut and don't like to do that..... so Hif44 it is...for now....... played wiv some cabling nd left it at that.....waiting for a Starter motor.......
Attached File  engine steady front on.jpg   79.74K   18 downloads
Attached File  hif44 in.jpg   80.06K   22 downloads
more soon.....
#203 minimuk
minimuk
  • 1,946 posts
Posted 15 December 2013 - 05:15 PM
Few jobs on Huye done today, aint looking it but, pain in the back jobs.....heater cooling hoses in siteue, chasing wires, what goes were, put heater in, and bineacle with 14000 ish miles on the clock!!!!???? Looking at the pictures, I need to do some polishing soon,....I do need a 'brake light switch bracket', I do need one, so if you have a spare one, give it a new home!!!Much appreciated ;D
Heater hoses through the L/H/D master cylinder holes
Attached File  cooling heater hoses in.jpg   40.2K   10 downloads
pain in the back job in a mini
all wired up 2Clock  bineacle
waiting for a few hose joiners, and bits and a Ramair filter plate for the Hif44.
Might start on the exhaust tmz.........more pain!!!
#204 minimuk
minimuk
  • 1,946 posts
Posted 24 December 2013 - 08:28 PM
yesterday I wired all up, connected cooling hoses, and fired him up on choke, a few turns and feck me, Huye is alive.......still need to do the down pipe and back box, but he is close now....
only 1 problem...the heater matrix leaks.....dripdrip....never the less.....he is alive!!!!!
Today I took the heater apart, from 1988 is the heater, looks like new on the outside, checked the matrix and is all good however the rubber O rings between the mating surfaces of the inlet and outlet pipes were perished.......stood still to long.....I put new O rings in and used a good sealant, tighten all the 4 small bolts and squeezed the excess sealant out, now we are waiting for it to dry. test it tmz on day after,if good exhaust will be next....... ;D
#205 Nossedout
Nossedout
  • 160 posts
Posted 26 December 2013 - 03:09 PM
great progress on huy'e...  looks stunning!!
#206 Nossedout
Nossedout
  • 160 posts
Posted 26 December 2013 - 03:10 PM
by the way: goodluck with the build!!
#207 minimuk
minimuk
  • 1,946 posts
Posted 26 December 2013 - 04:56 PM
Cheers, getting there.......I take it you have a clubby?
#208 minimuk
minimuk
  • 1,946 posts
Posted 26 December 2013 - 05:01 PM
after hard labor over the last few days(at work), I manged a few hours this afternoon, connected the matrix on it's own on the flow and return hoses, after a few minutes fetling with the pressure King and the carb set-up, started the engine and let him run for a few minutes to get all hot etc, no leaks........whehey, heater back on tmz and the exhaust....... ;D
#209 minimuk
minimuk
  • 1,946 posts
Posted 27 December 2013 - 07:54 PM
heater in,...no leaks,... crankcase breather painted and in position,...cooling topped up and ready to roll tmz,....that's after the exhaust fitting of course..... ;D
Attached File  engine with breather 1.jpg   76.1K   20 downloads
till next time....
#210 alex-95
alex-95
  • 6,025 posts
Posted 27 December 2013 - 07:56 PM
Good work mate
