Huy'e Clubby Estate '78
289 replies to this topic
#181 minimuk
minimuk
  • 1,947 posts
Posted 30 September 2013 - 04:22 PM
Not long now before judgement day mate ;D , just the little jobs that take time and then BRUM BRUM! (in theory :ohno:  :lol: )
Will the two different shades of brown fade into one another over time do you think minimuk ?
Keep us updated,
Cliff
paint will fade but not enough to match I think, so I will give the nearside a coat tmz like the bonnet etc  to have the same color all over in the end....in one year I will paint him again but in Gun-metal Grey......
#182 minimuk
minimuk
  • 1,947 posts
Posted 14 October 2013 - 07:25 PM
small update today, fitted new red-dot cones and new original Hi-lo's on the front end, new KYB shock's,.....will try and fit the new 7.5" disk set-up tmz defo on the nearside and start on refurbish offside hub
#183 minimuk
minimuk
  • 1,947 posts
Posted 15 October 2013 - 01:54 PM
love it when a plan comes together, nearside disk set-up in position,braided hose connected, nd no rubbing!! and offside hub nd disk ready to be put on, maybe tonite or tmz
Attached File  nearside disk set-up on.jpg   65.22K   11 downloads
every day a little bit is paying off ;D
#184 minimuk
minimuk
  • 1,947 posts
Posted 15 October 2013 - 05:00 PM
anyhow so I thought feck it, might aswell do it now......offside disk set-up on, wheels on and voila,...another milestone...in 2 days ;D
disk assembly
both on
Attached File  front disk set-up on.jpg   34.65K   13 downloads
HUY'e first steps with new front suspension and 7,5"Disk Brakes
Attached File  new disk brakes first steps 2.jpg   67.5K   19 downloads
well happy
#185 rally515
rally515
  • 3,848 posts
Posted 15 October 2013 - 05:51 PM
Haha nice progress, good when you can't resist going getting some more done ;)
#186 minimuk
minimuk
  • 1,947 posts
Posted 15 October 2013 - 05:59 PM
Cliff, I had a good run today, with a bit of tweaking here and there all fell into place, but that was planned way before....
#187 minimuk
minimuk
  • 1,947 posts
Posted 28 October 2013 - 08:28 PM
Fettling on with Huye,
bleeding brakes which is a pain in any case, but found out that the master cylinder is knackered, so new yellow tag one ordered
testing the clutch master cylinder under pressure, result no leaks
made up exhaust using 1.75" maniflow back box, new down pipe attached to a modified manifold knuckle link pipe,y piece cleaned and attached, bearing in mind estate is 30ish cm longer than a saloon.....
LCB mounted on the engine, which is still not in the car, will attach that onto the exhaust and see what noise he makes, might even give him a tune-up..... ;D
Edited by minimuk, 28 October 2013 - 08:46 PM.
#188 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 28 October 2013 - 08:30 PM
good work minimuk
#189 minimuk
minimuk
  • 1,947 posts
Posted 29 October 2013 - 05:03 PM
good work minimuk
Cheers Alex, I did put a new Master cylinder on and 15min later Presto feckin brakes work beautiful, tomorrow crank the engine with the exhaust and see what he does.....
#190 minimuk
minimuk
  • 1,947 posts
Posted 30 October 2013 - 05:14 PM
well, engine test with exhaust take 1
https://www.facebook...video_processed
enjoy ;D
#191 minimuk
minimuk
  • 1,947 posts
Posted 09 November 2013 - 04:19 PM
yep still at it, playing and tuning a @weber45dcoe@ is just one of those things, idling adjusting trials with different jets, mixture adjustments, air intake balancing, and gallons of petrol ..........but getting there ;D
https://www.facebook...&type=2
Edited by minimuk, 09 November 2013 - 05:59 PM.
#192 minimuk
minimuk
  • 1,947 posts
Posted 10 November 2013 - 04:16 PM
weber test 3,......to much advance I have been told....
https://www.facebook...007391040
#193 minimuk
minimuk
  • 1,947 posts
Posted 19 November 2013 - 09:38 PM
today test 4, with pressure regulator this time
still running rough, on further inspection after the video I noticed that cylinder 1+2 not firing on idle because the idle mixture jet was blocked with this piece of body panel
blown all the jets out tonight and reset all, even put an inline fuel filter on it just in case more panels going through.... ;D
#194 minimuk
minimuk
  • 1,947 posts
Posted 20 November 2013 - 05:26 PM
and this is todays symphony
#195 minimuk
minimuk
  • 1,947 posts
Posted 23 November 2013 - 04:31 PM
Final tuning is done, for now, lump is ready to go in next week...back on track  ;D
