Huy'e Clubby Estate '78
289 replies to this topic
#166 minimuk
minimuk
  • 1,946 posts
Posted 06 July 2013 - 09:55 AM
Ahaa so that was you on facebook with the bonnet issues, haha looking good :)
Cliff
cheers Cliff, thanks for the hint on facebook, enjoy reading the other treads on here, Evy and MUK... ;D
#167 minimuk
minimuk
  • 1,946 posts
Posted 06 July 2013 - 11:38 PM
another hot day,....... 1 hour off duty this afternoon, so back to second coat for the bonnet and N-side door
bonnet;
door
1500 wet-nd-dry tmz, then the next coat.......
#168 minimuk
minimuk
  • 1,946 posts
Posted 08 July 2013 - 05:01 PM
a bit hot today, few things done and then it was to hot.....for me anyway......
2 coats on NS wing
Attached File  front wing 1.jpg   89K   11 downloads
2 on scuttle end
Attached File  scullte end 1.jpg   21.26K   17 downloads
both doors done
few more rattle cans tmz.....
#169 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 08 July 2013 - 05:13 PM
Look's great minimuk :D
#170 littlenelly69
littlenelly69
  • 18 posts
Posted 14 July 2013 - 04:51 PM
When I had stinky I quite fancied the idea of using reverse rim cooper wheels and then fitting the clubman plastic hubcaps, would look kinda stock until you looked closely at it. Nice and subtle.
I looked into the Cosmic alloys......nice but not sure, just don't fancy alloys for certain reasons,will look into the reverse cooper wheels......
Looking great. fantastic pace too!
Cheers Elf. although the clubby looks good,not easy to do repairs and not damaging the good bit's but getting there.
As for progress today,...slow....had the door back in after the battle with the hinges might trow in a few shimms, it looks ok, and prepped wing and A-panel and scuttle closing plate for welding back on tomorrow morning,..... and done a few bottum door repairs
Thats about where I'm at, at the moment, great pics
#171 minimuk
minimuk
  • 1,946 posts
Posted 21 July 2013 - 10:09 PM
now Huy'e is outside with the boyz,
Attached File  huye out garage 1.jpg   72.72K   27 downloads
time to get started on the engine, all in boxes everywhere, but getting there
waiting for a few bits for the flywheel housing.......
#172 stealth05
stealth05
  • 625 posts
Posted 22 July 2013 - 05:28 AM
looking sweet mate
#173 minimuk
minimuk
  • 1,946 posts
Posted 22 July 2013 - 09:28 PM
2nd coat red on,....refurbished 59D4 dizzy, oil pipe in position, oh yes ordered bits for flywheel housing and so....from M-spares,M-sport and somerford mini's
Attached File  engine step 4.jpg   122.4K   14 downloads
crank him up in a few days ;D
#174 minimuk
minimuk
  • 1,946 posts
Posted 12 August 2013 - 08:04 PM
well a few weeks have passed, busy at work and did not manage to do anything to be honest,  although a few more bits done on the engine,and only got to sort the cooling and clutch, few weeks......and I had to get ready for the MITP, what a great weekend that was.
but today progress, bought al sorts of paint to get HUY'es inside painted as this needs doing before all get's moved back in, only done the seating area as the rear boot area is in excellent nick, gave all a rub down with scotch-brite pads, cleaned wiv petrol, then stone chip on first, then a coat of celly like brush-able russet brown paint. Well happy that it is out of the way now,  painted the front panel, sill flanges and corners of the rear door frame.
Attached File  inside 1.jpg   56.68K   11 downloads
Attached File  inside 2.jpg   74.15K   12 downloads
Attached File  front.jpg   55.67K   7 downloads
Happy with today's work indeed. ;D
#175 minimuk
minimuk
  • 1,946 posts
Posted 22 August 2013 - 11:04 PM
well been a few days, fettling with the engine it has been a journey indeed, all the bits are on except the rad, which will come tmz hopefully, weber45 is on. Tried to crank him, so anoying been waisting time and money to find a solution to get him going, new leads, spark-plugs,coil, fettling with timing for days but all is spot-on, so all points towards the battery, to weak not enough CCA. I will put a diesel battery on it tmz with a 330CCA + that should wake him up
this is what he looks like at the moment, without a rad,plugs and leads
Attached File  engine step 5.jpg   58.79K   12 downloads
more soon ;D
Edited by minimuk, 22 August 2013 - 11:05 PM.
#176 minimuk
minimuk
  • 1,946 posts
Posted 28 August 2013 - 03:40 PM
So here we are, 1275cc, cooper S head and Weber45 aat their first dance...
http://[email protected]
have a look ;D
#177 minimuk
minimuk
  • 1,946 posts
Posted 01 September 2013 - 12:30 AM
after a few days fettling, I discovered a damn oil leak, diffy housing plate on the driver side, ended up to be the bush and the pot-joint,drained the oil and took it all apart,.....replaced the bush and got a new pot-joint from M-Spares,but got to wait till I can get a big enough reamer to skim the bush a bit. Further bought a few bits for the weber45 conversion from the current 1380cc set-up to a 1275cc, Bought the right tubes, jets etc from Fast Road Cars LTD, I hope it is worth it as the replacement parts ain't cheap. All the parts for the cooling have arrived too so hopefully all should be put together by end of the week. ;D
Edited by minimuk, 01 September 2013 - 12:32 AM.
#178 minimuk
minimuk
  • 1,946 posts
Posted 20 September 2013 - 04:11 PM
been a while, busy at work and engine takes it's time,...but all de-calls are off and polished up with G3 compound
Attached File  102_0226.JPG   84.93K   17 downloadsAttached File  102_0227.JPG   73.31K   14 downloadsAttached File  102_0229.JPG   99.85K   18 downloads
happy sofar except 2 different russet colors, old and new......... :shades:
engine pics tmz
#179 minimuk
minimuk
  • 1,946 posts
Posted 30 September 2013 - 03:36 PM
few jobs done today, head lights front grill lamp covers, brake pipes and clutch pipes  for master cylinders, fitting master cylinders..........
Attached File  front grill and head lights 1.jpg   89.7K   7 downloadsAttached File  front grill and head lights 3.jpg   94.17K   3 downloadsAttached File  front grill and head lights 2.jpg   62.8K   1 downloads
connecting pedals tmz and work on dash a bit.....
#180 rally515
rally515
  • 3,848 posts
Posted 30 September 2013 - 03:42 PM
Not long now before judgement day mate ;D , just the little jobs that take time and then BRUM BRUM! (in theory :ohno:  :lol: )
Will the two different shades of brown fade into one another over time do you think minimuk ?
Keep us updated,
Cliff
