Huy'e Clubby Estate '78
289 replies to this topic
#136 minimuk
minimuk
  • 1,947 posts
Posted 28 May 2013 - 06:22 PM
not that long, but long enough ;D, Much else to do other than the welding?
 Alex, when welding is done, paint belly, engine bay and inside car and bonnet, put windows back in, then sort front 7,5" brakes. then engine.......after that, sand paintwork to have an etch, then primer him followed by top coat or 3. then we put him back together......
Edited by minimuk, 28 May 2013 - 06:23 PM.
#137 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 28 May 2013 - 07:15 PM
More than I thought, Are you still haveing the stripes down the side?
#138 minbin 69
minbin 69
  • 465 posts
Posted 28 May 2013 - 08:33 PM
looking good  muk :D  the way you get through it in 2 months you could finish that one and mine and still have time to start another one :lol:
keep up the good work..
#139 minimuk
minimuk
  • 1,947 posts
Posted 28 May 2013 - 09:28 PM
yep will put new de-calls on him after
well Minibin69, every day an hour or so keeps me on track , as it happens Evy is back on the agenda after....... ;D
#140 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 29 May 2013 - 07:18 AM
Coming along nicely. Looks on track for MITP.
#141 minimuk
minimuk
  • 1,947 posts
Posted 30 May 2013 - 09:56 PM
thanks Jagman, I have got to stay optimistic because I want to be there in Huy'e so my son can be there in MUK, so no pressure........
#142 minimuk
minimuk
  • 1,947 posts
Posted 30 May 2013 - 10:05 PM
today I was fettling on Muk's front wheel bearings, they where shot and the ball-joints had more sand in the then the beach in Brixham.....both their collar nuts where loose, I suppose that is a bad thing, no wonder the bearings had a hard time...I used 1 pnt of petrol to clean the lot and put the ball joints back on, now waiting for UPS with the MSpares delivery.....
Still managed to weld the last inner-sill repair piece in position and primered it after a good coat of Por15,
Attached File  OS outer sill repair 4.jpg   97.09K   12 downloadsAttached File  OS outer sill repair 5.jpg   89.1K   7 downloads
next bit will be sanding back the door-step lip and rear quarter lip, then topcoat inner-sill before offering outer-sill................. :gimme:
#143 minimuk
minimuk
  • 1,947 posts
Posted 03 June 2013 - 04:02 PM
great day again,.... :gimme:
both sides rear sliding windows new channels and glass back in position, now they slide again....rear wheel arches topcoat and floor under boot second topcoat, ready for petrol tank to go back under and subframe.Then I put top-coat under doorstep and inner-sill for "protection" and offered the new outer-sill, plug-welded under belly  and spot-welded the lip.
topcoat arch
Attached File  wheel arch repair 14.jpg   96.98K   6 downloads
new sill on
Attached File  OS outer sill repair 6.jpg   91.85K   12 downloads
if  second topcoat in dry in the morning I will wax-oil the petrol tank area and offer the tank back in position.....and maybe more..... ;D
#144 minimuk
minimuk
  • 1,947 posts
Posted 04 June 2013 - 06:01 PM
few hours today,
petrol tank was the mission today, ended up taking the petrol filler cowl out to get the "petrol grommet" in. Shifty was right,....Pain in the butt..... what a palaver, tank on then off again the on again, for some reason or another I started to remove the de-calls, filled a few more little holes sanded back and started to 'rattle can spray' the rear quarter, 2 layers sofar and its looking good, happy days
tank on and filler cowl, tiger sealed between cowl and panel;
Attached File  tank 4.jpg   98.57K   14 downloadsAttached File  tank 5.jpg   78.79K   11 downloads
rear quarter paint;
Attached File  wheel arch repair 15.jpg   86.65K   18 downloadsAttached File  wheel arch repair 16.jpg   36.19K   14 downloads
all good..... ;D
#145 minimuk
minimuk
  • 1,947 posts
Posted 08 June 2013 - 11:24 PM
subby is under and wheels- hilo's adjusted, double seam weld the outer sill and footwell
Edited by minimuk, 09 June 2013 - 01:03 AM.
#146 minimuk
minimuk
  • 1,947 posts
Posted 09 June 2013 - 06:51 PM
after work today, I managed to sand back the seam-welds and applied seam sealer on the outer-sill joints, foot-well joints and A-panel inner-wing joints,
Attached File  OS outer sill repair 13jpg.jpg   95.71K   3 downloads
hopefully I am able to clean the belly of grease and mud tmz, so I can stone-chip it and apply 1  layer top coat  :goaway:
#147 minimuk
minimuk
  • 1,947 posts
Posted 11 June 2013 - 11:10 AM
few paint jobs on the O/S belly this morning,
cleaned belly with heat-gun,wire brush and petrol
applied 2 coats of zinc primer
followed be 2 coats of stone-chip
ready for first top coat,.....later.... ;D
painstaking up-side-down painting, first top-coat is on :gimme:
start on N/S tmz
Edited by minimuk, 11 June 2013 - 05:19 PM.
#148 hoody99
hoody99
  • 699 posts
Posted 11 June 2013 - 10:41 PM
Looking good I'm just doing similar now just the stone chip to go on lol
#149 minimuk
minimuk
  • 1,947 posts
Posted 11 June 2013 - 11:32 PM
good luck with yours, I still got a long way to go, but only have 7 weeks........MITP.....
#150 minimuk
minimuk
  • 1,947 posts
Posted 12 June 2013 - 03:50 PM
finished topcoat under OS wing, and a few other bits, welded a-panel wing stiffener, and cleaned the NS belly ready for zinc Primer
OS front inner arch and cleaned belly
sanded back filler on A-panel scuttle and etch primed it
refurbed yellow tag brake master-cylinder to finish, enough for the day ;D
Edited by minimuk, 12 June 2013 - 07:23 PM.
