Kad Engine Nearly There Now
#31
Posted 19 February 2013 - 09:32 PM
#32
Posted 19 February 2013 - 11:27 PM
Engine/Gearbox
1399cc, KAD 16v Cylinder Head Kit - Race 200, 30x26mm 5mm stem stainless steel valves, Race 200 camshaft profile. Double valve springs
alloy valve spring top caps, steel tappets. KAD Steel Forged H-Beam Con Rod Set and JE Forged Pistons. KAD all 3 steel main caps with 4 bolt centre. Paul Ivey EN40B crankshaft. 7075T6 KAD alloy flywheel and back plate assembly, Grey pressure plate and paddle clutch, high capacity oil pump with Mocal remote oil filter assembly, twin Weber 45 DCOE's with double alloy velocity stacks, K&N air box filter, Facet fuel pump with filter king regulator, 1.08:1 S/C transfer gears, MED Race dog engagement gear kit, KAD pinion bearing support housing, centre oil pickup, Tranex LSD with S/C crownwheel and pinion, group A driveshafts with tripoid inboard joints, Brise starter and alternator, Davies Craig electric water pump, Mocal oil/water heat exchanger, front mounted bespoke alloy radiator and header tank with twin Yamaha R1 cooling fans and electronic fan controller, Samco hoses throughout, Piper race exhaust manifold, Maniflow full race miglia twin box exhaust, Weber Alpha silver 3-d mappable ignition,
Thats enough for now, i'll post more of the rest of the car specs later.
Dave
#33
Posted 19 February 2013 - 11:29 PM
#34
Posted 19 February 2013 - 11:42 PM
Dave
Edited by tvrdave, 19 February 2013 - 11:49 PM.
#35
Posted 20 February 2013 - 12:03 AM
Also mild steel is more tensile.
Who knows why,does anybody know why on here ?
#36
Posted 21 February 2013 - 09:36 PM
Seam welded shell with Miglia welded in rollcage, KAD alloy radius arms, KAD front and rear anti roll bars, Gaz adjustable front and rear dampers with rear coilovers, all dampers mounted with spherical bearings, stiffened / modified subframes front and rear all solid mounted, adjustable front tie rods and lower arms, Vented discs with 4 pot KAD calipers, 2 piece glassfibre front, lightweight doors, glassfibre boot lid, modified lightweight front hubs, Quick Motorsport adjustable electronic power steering, OBP bias pedal box, interior mounted gear linkage, alloy fuel tank and boot floor, MB wheels 8 x 10 split rim alloys, Hoosier slick tyres, polycarbonate windows, miglia extra wide arches, custom dashboard, i'm sure there's more but thats all i can think of at the moment.
Just don't tell her indoors what it all cost.
Dave
Edited by tvrdave, 22 February 2013 - 11:51 PM.
#37
Posted 21 February 2013 - 09:40 PM
#38
Posted 21 February 2013 - 09:43 PM
Dave.
#39
Posted 06 May 2013 - 09:36 PM
A little more progress finally.
Edited by tvrdave, 09 May 2013 - 05:43 PM.
#40
Posted 06 May 2013 - 09:48 PM
Damm that's very nice!
Love the colour too, not that I have a thing for blue!
#41
Posted 09 May 2013 - 05:44 PM
Well hopefully it will be hitting the track soon. Be interesting to see how it drives.
#42
Posted 09 May 2013 - 06:13 PM
oh my! what a fantastic piece of kit, i mean that engine is just awesome, pure perfection, but add to that the car its going in and you have got a fully sorted machine!
i can only imagine how much that entire thing has cost, i would love to see this in action. i dont suppose your ever going to take it to shelsley walsh are you? its pretty close to me, please bring it there!
#43
Posted 09 May 2013 - 06:27 PM
I am thinking of bringing it to shelsley at some point.
Best not to know what its cost really, i don't want to think about that too much lol.
#44
Posted 11 June 2013 - 09:47 PM
Well the car finally made it out to the track at Curborough for a test and shake down. Unfortunately it was way too wet to think about any full speed runs, but it went very well and only had a couple of very minor issues which are now fixed. It pulled very well, revved freely, gearbox felt fine, so all in all i am very satisfied. Just need a good dry test day now for some final setup and it's ready to race.
Edited by tvrdave, 11 June 2013 - 09:47 PM.
#45
Posted 12 June 2013 - 06:38 PM
