Wheel Nuts For Mini Lights
15 replies to this topic
#1 mex
mex
  • 42 posts
Posted 04 February 2013 - 10:34 PM
hi
just bought some mini lights without nuts so need 16 of them
what nuts do i need are they special ones or will any mini nuts do
cheers
#2 jaydee
jaydee
  • 8,565 posts
Posted 04 February 2013 - 11:01 PM
You need the appropriate nuts for them, what minilites are they?
#3 Cooperman
  • 23,278 posts
Posted 04 February 2013 - 11:17 PM
Are they genuine Minilites or 'look-alikes'?
#4 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 05 February 2013 - 08:27 AM
Genuine Minilites use different nuts depending on what size the wheels are.
Mini Lights (The old MWS wheels) use pre-84 round seat nuts - at least mine do.
#5 Cooperman
  • 23,278 posts
Posted 05 February 2013 - 11:35 AM
My Minilites use domed sleeve nuts with chamfered washers.
#6 Scott@minispeed
Scott@minispeed
  • 200 posts
Posted 05 February 2013 - 11:39 AM
If you can put a picture of a wheel on here I can tell you what you need
#7 Vipernoir
Vipernoir
  • 782 posts
Posted 05 February 2013 - 02:37 PM
As do my genuine Minilites (note different spelling), though it should be noted that the 6" wheels use a different nut to the 4½" wheels.
If you talked nicely to the chaps at the factory you could get nuts with the logo embossed in the end and double thickness chrome.
My Mini Lights (note different spelling) use pre-84 rounded nuts.
My Japanese spec 12" Minilites (yes, genuine and nigh-on unique) use 60° taper nuts.
My Supalites (or Ultralites) use 60° taper nuts.
Really, we need to see a photo of the wheel and the nut seat to make certain you have the right nuts.
Use the wrong nuts and at best you will bugger the wheel, at worst you can snap the studs and lose the wheel while driving.
#8 mex
mex
  • 42 posts
Posted 05 February 2013 - 04:39 PM
hi
thanks for replies
here is a pic of the wheel, just bought off ebay so not got them yet
they are spelt mini light
i hope they are not mws wheels, i have had a lot of problems with tyres on the 6 inch ones i had
these are 5 inch
cheers
Attached File  $T2eC16ZHJFoE9nh6pNWjBRBYC7!0lQ~~60_35.jpg   15.13K   14 downloads
#9 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 05 February 2013 - 05:34 PM
If it turns out you need the taper type (not the rounded ones) let me know. I have a brand new set I bought at Bingley after being told they were the right ones for my wolfies. They are no use to me so you could have them cheap.
#10 mex
mex
  • 42 posts
Posted 05 February 2013 - 05:39 PM
pmd
cheers
#11 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 05 February 2013 - 05:41 PM
pmd
cheers
Replied :-)
#12 Vipernoir
Vipernoir
  • 782 posts
Posted 06 February 2013 - 08:52 PM
Initial impression is that they are an MWS Mini Light and need a pre-84 rounded seat nut.
A closer pic of the seat is need for a certain diagnosis.
60° nuts are not compatible.
#13 mex
mex
  • 42 posts
Posted 09 February 2013 - 09:06 PM
hi
got wheels today
here is a better pic
cheers
Attached File  DSCF1229 (1).JPG   64.38K   13 downloads
Attached File  DSCF1232.JPG   42.5K   14 downloads
#14 leo5090
leo5090
  • 22 posts
Posted 09 February 2013 - 10:59 PM
I went to wilco and just bought a set for 20 odd quid fit perfectly :)
#15 Vipernoir
Vipernoir
  • 782 posts
Posted 11 February 2013 - 12:34 PM
It looks to me as if they have been used with the wrong nuts at some point - the seats appear to be chewed up from where a 60° taper nut has been jammed in and graunched up the rounded seat base.
My guess would be that pre-84 rounded seat nuts were the original requirement, but I'd recommend getting them professionally inspected with an eye to needing inserts fitted.
