Best Oil
71 replies to this topic
#46 jaydee
jaydee
  • 8,565 posts
Posted 29 January 2013 - 10:21 AM
Use it only on a scrap engine, using castrol R is like putting castor oil in the engine :P
#47 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 29 January 2013 - 10:36 AM
Will Just put a thimble full into the fuel tank then.. 8) same effect though hahaha
#48 minimaxie
minimaxie
  • 1,687 posts
Posted 29 January 2013 - 11:44 AM
I only ever use Millers 20w50 Classic Mini Oil, the one that actually says "Classic Mini Oil" on the bottle
http://www.ebay.co.u...=item3f2100a8f6
Does the job great, makes the gear changes feel nice and smooth, waaaay better than the crud 10w40 that must of been in there before!
Edited by minimaxie, 29 January 2013 - 11:44 AM.
#49 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 29 January 2013 - 01:48 PM
Does anyone want to pipe up on behalf of us automatic owners?
20w50 is a no no.
Too harsh on the clutch plates apparently.
#50 jaydee
jaydee
  • 8,565 posts
Posted 29 January 2013 - 01:57 PM
You need 10w40 for the automatic
Comma sonic 20w50 is the best oil for running in as its above 2000ppm zinc content and has low detergents.
Edited by jaydee, 29 January 2013 - 01:57 PM.
#51 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 29 January 2013 - 03:45 PM
I was advised by the shop that built my engine to use Millers 10w/60 once fully run in. I dont even know where you can buy this?
#52 firstforward
firstforward
  • 824 posts
Posted 29 January 2013 - 04:27 PM
http://www.camskill.co.uk/m1b42s5592p69070/_MILLERS_OIL_-_CFS_10W60_Fully_Synthetic_Oil_-_5_Litre_-_5L_/RS_GB
#53 Ipod
Ipod
  • 2,024 posts
Posted 29 January 2013 - 05:31 PM
ok that millers 20w50 mini oil better be good, i just orderd 10ltrs of the stuff...as i usually use 10w40 ;D
#54 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 29 January 2013 - 06:30 PM
"shameless plug"
And the OP asked for 'the best oil'. That is Valvoline VR1 20w50 now that Kendall 20w50 is NLA in the U.K.
if anyone wants any cheap give me a shout as i've got some to spare ;-)
#55 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 29 January 2013 - 06:39 PM
Ok, so to spice this up a bit- what about additives?
#56 CityCharlie
CityCharlie
  • 56 posts
Posted 29 January 2013 - 07:02 PM
AFAIK (from previous advice) most additives are snake oil. But they may aid in prolonging your engine life when it is hanging!
FWIW, I was going to use Valvoline VR1 20W50 in my Mini or Millers Mini 20W50 oil. However, when I spoke to a certain oil seller he recommend 10W40 motorbike oil (since motorbikes also share the gear and engine oil, believing that the 20W rating does not provide adequate cold start protection and that the 50 weight is too thick for an otherwise good condition engine. What are your thoughts on this?
#57 jonny95
jonny95
  • 217 posts
Posted 29 January 2013 - 07:09 PM
for spark plugs i use ngk bp6es
With the op asking witch plugs a 1275 spi, they would be wanting the bpr6es. Being as they have built in resistors and are more suited to electronic ignition the spi would be fitted with.
i stand corrected
does this mean i should be using bpr6es as i have electronic ignition on my 998??
Edited by jonny95, 29 January 2013 - 07:09 PM.
#58 jaydee
jaydee
  • 8,565 posts
Posted 29 January 2013 - 08:16 PM
1500ppm..........
The pds from 2011 clearly states:
T.B.N. 8.0 mg KOH/g
Sulphated Ash 1.3%
Zinc 0.20%
Calcium 0.26%
Phosphorus 0.19%
http://www.commaoil.com/productsguide/view/6/247
#59 jaydee
jaydee
  • 8,565 posts
Posted 30 January 2013 - 09:36 AM
They're used to change oil specs frequently, causing a lot of confusion ie: castrol XL was originally a healty 1400 ppm, now its just 800 if you got a lucky batch..
So probably sonic was 1500 and then updated to 2000ppm in 2011, although some say anything more than 1800 is not very reccomendable
#60 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 30 January 2013 - 10:39 AM
Does zddp cause a problem with clutch plates in an auto seeing as they are permanently submerged in the oil?
