Best Oil
#31
Posted 28 January 2013 - 09:25 PM
If so its very very poor..............
#32
Posted 28 January 2013 - 09:28 PM
#33
Posted 28 January 2013 - 10:11 PM
With the op asking witch plugs a 1275 spi, they would be wanting the bpr6es. Being as they have built in resistors and are more suited to electronic ignition the spi would be fitted with.
for spark plugs i use ngk bp6es
what is the ideal for a carbed 1275 ?
#34
Posted 28 January 2013 - 10:13 PM
I'd say 20/50 and get the best oil you can afford..
#35
Posted 28 January 2013 - 10:33 PM
For 998/1275 on points BP6es and the BPR6es for standard or points replacement electronic ignition.
Also if you look in the newer Haynes, you can use champion RN9YCC for both 998/1275.
#36
Posted 28 January 2013 - 10:42 PM
#37
Posted 28 January 2013 - 10:59 PM
dare i ask which coolant to?
#38
Posted 28 January 2013 - 11:01 PM
#39
Posted 28 January 2013 - 11:07 PM
#40
Posted 28 January 2013 - 11:15 PM
Dont overtighten the sump plug or you'll crossthread the sump as its an alloy casting.
#41
Posted 28 January 2013 - 11:18 PM
ghaha cheers guys, so 20w50 and bp6es
Your spi will have a black module on the side of the dizzy meaning it will be electronic, it will run better on bpr6es plugs.
As for coolant, the old blue stuff is all you need for the cast iron aseries.
#42
Posted 28 January 2013 - 11:23 PM
#43
Posted 28 January 2013 - 11:24 PM
#44
Posted 28 January 2013 - 11:26 PM
#45
Posted 28 January 2013 - 11:30 PM
Mmmmmmmm smells nice! May run the miglia engine on it seeing as it s not going to be used other than quick sharp racey time
