Posted 28 January 2013 - 09:19 PM
I think there is some confusion here. The primary gear has no effect on the transfer gear end float, but the primary gear should have no more than a0.008" end float and the transfer gear should have no more than 0.006" end float.
Now, to check the transfer gear end float you fit the transfer gear and transfer gear case to the gearbox, without the engine on the gearbox, and 'nip' it up with the new gasket fitted to the transfer gear case. This is called a 'trial build'. You can then measure the end float of the transfer gear and fit thicker or thinner thrust washers as necessary. Then remove the transfer gear case keeping the same gasket as some can be a different thickness. Never use grey coloured ones - the only ones to use are the pink-ish coloured ones. The grey ones can be too thin and are rubbish.
Once the transfer gear float is correct you fit the engine onto the gearbox and check the end float of the primary gear. the primary gear end float is determined by the inner thrust washer which is quite thin and has a chamfer on the inside diameter which sits towards the engine. If the end float is too much you mmeasure what you have and work out what you need then order a thicker inner thrust washer of the desired thickness. The primary gear is located by an outer thrust pad and a 'C'-washer. It is important to fit the C-washer downwards with the engine at TDC on pistons 1 & 4.
You have to measure everything, work out what you need and then order the correct thickness parts to achieve end floats which are within the limits stated.
