If I remember correctly part of the reason for fitting the ball-bearing in place of the shuttle/bullet valve is to mitigate "sticking" shuttles. In the "good old days" the fix for this was to drill through the back of the shuttle, giving any "foreign objects" trapped in the bore of the valve somewhere to go, but the power of perceived wisdom tells you that "you gotta have a ball and spring if you're building a 'performance' engine............"
Other variations on the theme exist, in the MGB world they have a "tadpole" valve, which is a ball with a "tail" if you can visualise it. The "tail" fits into the end of the spring, and this would perhaps help if the spring and ball started to cockle over in the bore, but I'm also going to assume that the seat area is to suit a ball rather than a taper.
I too have suffered from this "ball and spring" delusion in the past, and for a while I ran the ball-bearing with a standard i.e. non-S spring, and the oil pressure was back into the "normal" range but there were some strange pressure fluctuations. Now I run a standard spring and shuttle, as per the original design.
Phil.
