First Motion Shaft End Bearing Snap Ring
5 replies to this topic
#1 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 26 January 2013 - 12:26 PM
As the title says, I am fitting a new eand roller bearing. The one that goes into the transfer case, however I need to remove the old outer race from the transfer housing.
How do I remove the black snap ring, holding the outer race in the transfer case? I am unsure if there is a "correct Tool" for the job.
Also Is it a one use ring?
#2 grahama
grahama
  • 2,442 posts
Posted 26 January 2013 - 01:10 PM
Can't remember how I got my lock ring out, if indeed I did, but getting the outer race proved nearly impossible so I ended up taking it to a local machine shop who had it out and a new one in in a few minutes. Cost me nothing as they were doing some other work for me but can't see them charging much at all. It saves the risk of any damage to the case or place the outer race sits in.
Sorry can't be much more help,
Graham
Edited by grahama, 26 January 2013 - 01:10 PM.
#3 AlexMozza
AlexMozza
  • 1,248 posts
Posted 26 January 2013 - 01:19 PM
Ill take it to work and use a puller :)
Thanks.
Unless anyone else can shed some more light?
#4 The Principal
The Principal
  • 763 posts
Posted 26 January 2013 - 01:26 PM
http://www.guess-wor...Tech/spigot.htm
#5 AlexMozza
AlexMozza
  • 1,248 posts
Posted 26 January 2013 - 07:08 PM
Love the last bit! Ill try it later :D
#6 AlexMozza
AlexMozza
  • 1,248 posts
Posted 27 January 2013 - 09:02 AM
Also, do you need a puller for removing the old bearing. I have removed the circlip but the bearing wont budge!
