Door Card - Plastic Membrane
Posted 25 January 2013 - 09:42 PM
https://easyspacesho...lastic_Sheeting
is this something I should have in place/recommended to have in place?
Thanks in advance for any assisatnce you maybe able to provide.
Kind Regards
Leeroy.
Posted 25 January 2013 - 09:52 PM
The water shedder prevents the water running inside the car, hence the name.
It's just a polythene sheet stuck to the inner metal door skin covering the access hole used to fit the window and winder mechanism. It is glued to the metal by the use of butyl wich stays sticky and flexible for about 20 years! You can just use silicone sealant to glue it on.
The trim clips are then pushed into the door inner throught the polythene sheet.
Hope this helps
Posted 25 January 2013 - 10:02 PM
It's called the water shedder, and yes you should fit them to the inner door skin, behind the door trim panel ( called door cards by the modern lot). Water from the window channel runs inside the door, and then exits via the drain holes.
Hope this helps
That may well explain some water getting inside that shouldn't as my car does not have this barrier.... shall be adding that to my shopping list.
Thanks once agian.
Leeroy. Fairhurst
Posted 25 January 2013 - 10:30 PM
Posted 26 January 2013 - 12:20 AM
Posted 26 January 2013 - 01:02 PM
Posted 26 January 2013 - 01:07 PM
Posted 26 January 2013 - 03:31 PM
Doug as you know the mk 1 with sliding windows has sealed bottom window channel and drain tubes, ingenious design from Issigonis. Incidentally Sir Alec hated the wind up windows as it robbed some of the storage and you got wind buffeted if you lowered them! That's why he insisted that sliding windows were retro fitted to his 9X prototypes!
Posted 26 January 2013 - 03:57 PM
Anyway, back to the OP, you have lots of options to prevent water and drafts from getting in the car and the plastic barrier (purchased or homemade) is a good idea.
Posted 26 January 2013 - 04:59 PM
Just use duct tape, to cover the holes up............
I like Mike's idea of the B&Q membrane.
However, the above is just a bodge!
Posted 26 January 2013 - 06:51 PM
but just using duct tape is a bit of a bodge.
Yes but is there actually anything wrong with it? I mean it's not actually visible once the door card is fitted and waterproof duct tape does do a very good job of sealing out moisture, so is there an actual downside to using duct tape or are you both just being purist about this?
Posted 26 January 2013 - 09:20 PM
Posted 26 January 2013 - 09:28 PM
Posted 26 January 2013 - 10:57 PM
In the MG/Triumph world it is very common for the top of dashboards to crack from sun exposure. While you can replace the whole thing, a quick fix is to fit a "coverlay" made of blow molded, textured plastic. The coverlay extends forward and is tucked under the bottom edge of the windshield rubber to hold its forward edge down. The back edge is held to what's left of the old dash using strips of thick butyl rubber. It works great and when done properly it easily conceals that poor old cracked dash.
Posted 26 January 2013 - 11:01 PM
Just use duct tape, to cover the holes up............but just using duct tape is a bit of a bodge.
If you're going to do a job, do it properly to the right standards
