Mazda 323 1986 Retro/resto
52 replies to this topic
#46 cityspeed
cityspeed
  • 193 posts
Posted 06 May 2013 - 10:44 PM
Engine seems to be smooth but my gearbox is a little stiff, 2nd can be a pain from cold, and reverse is a pain, I'm checking out the linkage for wear etc but there is defiantly a transmission noise resonating from some where,,,,,Saying that ive been using it every day and it hasn't failed me yet "touch wood"!
Yeh there is loads of room in the boot, my box is going to make the most of the spare wheel well, I will be putting rear seats back in, Ive just been without a car for 5 months so I have so many jobs to do, so there is no point messing up that lovely 80's cream + brown interior!
I went in a car trimmers / upholsterers at the weekend and managed to match the brown chocolate vinyl thats on the dash etc he had loads of it so if you need anything re-trimmed drop me a line,
#47 cityspeed
cityspeed
  • 193 posts
Posted 06 May 2013 - 10:59 PM
Lowered 40 mm all round on 13 steely's + big tires
919831_10152810775915296_652505625_o_zps
467124_10152810774485296_282200853_o_zps
921772_10152810772845296_1863043482_o1_z
14x6 1986 Mazda RX7 Rims with Toyo 350 165/50/r14
474556_10152810771540296_1175722319_o_zp
quick clean
919472_10152810770930296_1148034150_o_zp
Job done! on the road    :shifty:
whats next!
Edited by cityspeed, 23 September 2013 - 12:20 AM.
#48 Reetek
Reetek
  • 14 posts
Posted 13 May 2013 - 05:18 PM
A set of pressed plates would finish it off nicely! Love those retro rims, looks stock. I had a bump in nearly the exact same place on my passenger arch, weird!
#49 cityspeed
cityspeed
  • 193 posts
Posted 23 September 2013 - 12:12 AM
Been driving this car almost every day now for past 4 months and its been great, feel really attached to it now. It hasn't let me down yet! but some millage and some shoddy road surfaces have battered the once set up car I owned 4 months ago,
New issues :
  •                      possible dent to front drivers side alloy (inner edge),
  •                      tracking slightly out
  •                      My rear shocks feel blown! even with the springs its very bouncy dampers need replacing
  •                      Started to drink more fuel + felt rich low down in the rev range
  •                      Boot struts non operational (broom handle is current cure)
To be fair I should have serviced it better before I started doing lots of motorway miles but now I feel guilty and have the time to sort some of issues out, I like to do as much of my own mechanic's so its just getting round to it, but I'm fed up of it bouncing around now!
Parts recently arrived:
K&N Direct replacement Cleanable foam version
Castrol Oil
3 oil filters
HT leads Bosch
Plugs (Purchased Denso twin tips? normally go for NGK)
Front brake pads
Need to order:
Rear boot struts (polished/chrome)
Rotor Arm
Dizzy cap  (finding these two alternator parts hard to find now, almost most of these come from oversea's it seem's from suppliers,)
Set of Mk2 golf front coilovers, Possibly rear replacement standard dampers as Iv'e found Some KYB ones at £50 for the pair
Recent work:
  • Upgraded 0 gauge ground zero power supply battery/alternator earth,terminals, In line fuse + cable fitted under carpet for amplifier
  • New speaker pods on dash + tweeters on pillars, front stage almost done Sounds great! door's + boot to follow
  • Carb cleaned
  • Air filter fitted / supply hose made more direct
Worklist for the next few days:
  • Engine flush Oil change after motorway tear
  • Fit rest of service parts mentioned above
  • Rebuild brakes (I think either sticky pad or caliper carriers not greased + fit new pads)
  • Door speaker builds (all ice work undertaken by my house mate Henry)
  • Weld up door lock hole Passenger side (car broken into previously) going for solenoids
  • Paint boot area with rustoleioum before install    84b84eea-f17d-43f4-9501-45179612a1a2_zps
Edited by cityspeed, 23 September 2013 - 12:15 AM.
#50 cityspeed
cityspeed
  • 193 posts
Posted 23 September 2013 - 12:17 AM
#51 CiaranNixon
CiaranNixon
    Starting My Mini Up
  • 1 posts
Posted 29 October 2013 - 02:24 PM
Hey guys I have 1989 mazda BF 323 saloon nees help sourcing parts and some general info on how to source bits sound
#52 Reetek
Reetek
  • 14 posts
Posted 18 June 2014 - 12:39 PM
Been a while since ive been on here. Not sure if anyone else knows of this company but if you email [email protected] and speak to patti they an order in loads of 323 panels. Ive had 2 rear arches and a set of wings. They do sills and all sorts! Will post some photos soon as mazda is nearly just a rolling shell now.
#53 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 18 June 2014 - 02:27 PM
Carz2 are great. I bought some civic EG panels from them and they're spot it. Great price too.
Loving the mazda!
