how do you remove drive flanges on 12" (8.4") setups?
29 replies to this topic
#16 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 07 April 2006 - 09:41 PM
1 5/16
#17 GraemeC
GraemeC
  • 7,438 posts
Posted 08 April 2006 - 07:38 AM
Unless its a very late set in which case it may be 34mm as I've found out recently - chances are though it will be 1 5/16".
#18 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 April 2006 - 07:44 AM
If the cv does not come out easily, then as said before, is fubar so there's no point being delicate with it... the only part of the unit you will be needing is the hub.
An alternative to using a hub puller is to attach a wheel, with a large penny washer or plate over the hole and tightening up the wheel nuts
#19 GraemeC
GraemeC
  • 7,438 posts
Posted 08 April 2006 - 07:50 AM
I'm confused - you state at the beginning you've removed the big nut but now you're asking what size socket you need??!!
If that's not off there's no way this thing will come apart.
#20 JoeBodge
JoeBodge
  • 716 posts
Posted 08 April 2006 - 09:35 AM
1 of them came off realy easily, but on the second disk setup - it wont budge, the first came off with an adjustable wrench, but that aint working on the second. so i need to know the socket size
#21 pikey7
pikey7
  • 3,824 posts
Posted 08 April 2006 - 09:55 AM
make sure you turn it the right way! (they are handed threads)
#22 miniboo
miniboo
  • 9,327 posts
Posted 08 April 2006 - 10:01 AM
not on the front they arent
rear ones are handed
#23 JoeBodge
JoeBodge
  • 716 posts
Posted 08 April 2006 - 10:04 AM
lefty loosey, righty tighty
#24 pikey7
pikey7
  • 3,824 posts
Posted 08 April 2006 - 10:08 AM
Are you sure? I'm relatively sure mine are (It was a few weeks since I was playing with them, but as you point out, I could be thinking of the rears). If not, then they bally well should be! :w00t:
#25 miniboo
miniboo
  • 9,327 posts
Posted 08 April 2006 - 10:37 AM
if they were handed then you would have to buy n/s and o/s cv joints!!
which as far as i know you can't!!
plus i am sure i read a thread the other day and Dan said that they weren't
#26 pikey7
pikey7
  • 3,824 posts
Posted 08 April 2006 - 11:01 AM
'tis my bad. I just looked and they aren't handed. They should be though!
#27 Jammy
Jammy
  • 25,397 posts
Posted 08 April 2006 - 12:14 PM
Yea I made the same mistake a few days ago and said the fronts were handed before Dan and miniboo kindly reminded me they weren't!
And I agree, they should be! :w00t:
#28 andyps
andyps
  • 132 posts
Posted 08 April 2006 - 05:54 PM
I've got a similar problem - need to take the hub off to replace the bearings but there doesn't seem to be eny way to get the CV joint out of the bearings - I have a replacement so I have been belting it with a lump hammer but it still hasn't moved (so far I have had the nut on so I can put it back on the road to drive to a gargae if need be). The disk came off easily, but the hub will not separate - any thoughts on how to sort it?
Andy
#29 andyps
andyps
  • 132 posts
Posted 09 April 2006 - 08:56 PM
Just to add - I took the driveshaft and hub off today so I could get at things better, but still no joy with getting the shaft out of the bearings. I tried all sorts, in the end welding a bead onto the bearing inner to really heat it up in the hopes it would then move, but even whilst it was still really hot belting it with a lump hammer wouldn't shift it!
Taking the bits to the local gargae tomorrow to see if they can separate it, if not I will have to get a new hub :-*
#30 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 April 2006 - 09:47 PM
As Miniboo said ages ago, you need to take out the taper washer that is still in the flange in your picture. If you don't, it will not come apart.
