how do you remove drive flanges on 12" (8.4") setups?
Posted 07 April 2006 - 02:29 PM
Ive been trying to take them apart, so i can re-build them up.
I have taken off the callipers, removed the big nut from the middle of the drive flange, and removed the 4 retaining bolts. but the drive flange still wont move-
any ideas?
Posted 07 April 2006 - 02:32 PM
Posted 07 April 2006 - 02:36 PM
Posted 07 April 2006 - 02:43 PM
Also, how are you 'modifying' them to fit under 10's, if you are intending to use the existing mini disk drive flanges, then your choice is to get the disks machined down to 7.9 and then use alloy 4 pots.
Edited by GuessWorks, 07 April 2006 - 02:44 PM.
Posted 07 April 2006 - 02:58 PM
If so then support the hub on wooden blocks high enough to keep clearance behind the CV and then tap that out by knocking on the threaded part with a soft faced hammer (loosely screw the slotted nut back on until its flush with the end of the thread too).
Posted 07 April 2006 - 03:24 PM
and to purchase a set of 4 pot alloy callipers and 7.5" disks also from minisport
Posted 07 April 2006 - 03:40 PM
The 7.5" disks have a different ( cooper S ) drive flange..
as GraemeC has said. smack the end of the CV ( big threaded part ), if that's tight, it indicates that the CV and bearings have been heated due to lack of lubrication, and are probaby scrap anyway...
Posted 07 April 2006 - 04:02 PM
Posted 07 April 2006 - 04:35 PM
[attachment=14529:attachment]
should i screw back in the 4 retaining bolts - so the disk and flange both come off?
Posted 07 April 2006 - 05:55 PM
Posted 07 April 2006 - 06:01 PM
you'll just collapse the driveshaft where the split pin goes through and have to buy new CV joints. (Yes, I found out the hard way! Good job one of the CVs was knocking!)
Put the nut back on so that nut covers the split pin hole. Then get a thick (5mm ish) piece of steel that you can drill though and put on opposite wheel studs, ad over that top of the cv thread/big nut. then put the nuts on and give each one a turn at a time to make sure it pops out evenly. Alternatively, buy a hub puller!
if you have one could i borrow it lol
Posted 07 April 2006 - 06:24 PM
rather than me trying to explain read the and look at the picturs in the FAQ section for changing brakes.
what i do is give the washer a whack with a blunt metal rod andf it tends to dislodge that way.
http://www.theminifo...?showtopic=9930
Posted 07 April 2006 - 09:34 PM
one more thing - what size socket do you need for the castle nut on the hub?
