New Engine And Box Ordered, 1275 +40
89 replies to this topic
#1 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 01:27 PM
As above guys i have just made payment on my new engine and gearbox, I have gone for a 1275 +40 with a 276 kent cam and 3.4 diff, i have the option of 1.5 roller rockers, what are your suggestions should i buy the rockers or would this engine be suitable as it is.
cylinder head -
1 2G940 MODIFIED BIG VALVE CYLINDER HEAD
NEW BULLET NOSED BRONZE VALVE GUIDES
REFACED/SKIMMED TO SUIT COMPRESSION RATIO
ALL VALVE SEATS REGROUND AND LAPPED IN
EXTRA STRONG VALVE SPRINGS
NEW COPPER HEAD GASKET
CHROME ALLOY POLISHED HIGH LIFT ROCKER COVER WITH CHROME CAP AND CHROME T-BARS
MG TURBO ROCKERSHAFT ASSEMBLY FITTED
NEW WATER TEMPERATURE SENSOR FITTED
NEW EXHAUST MANIFOLD STUDS/NUTS/WASHERS FITTED
NEW THERMOSTAT HOUSING STUDS/NUTS/WASHERS FITTED
NEW HEATER TAP STUDS/NUTS/WASHERS FITTED
NEW NGK SPARK PLUGS FITTED
NEW HIF44 CARB + ALLOY INLET MANIFOLD AND K&N CONE TYPE FILTER
1275 A+ CYLINDER BLOCK
HONED SKIMMED/DECKED TO SUIT HIGH COMPRESSION RATIO
+40 FAST ROAD PISTONS ON LIGHTENED AND BALANCED A+ CONRODS
ALL NEW CORE PLUGS FITTED
NEW OIL PRESSURE RELIEF VALVE
NEW OIL TEMPERATURE SENSOR FITTED
NEW FUEL PUMP BLANKING PLATE FITTED
NEW HIGH CAPACITY WATER PUMP FITTED
CAMSHAFT
KENT 276 CAMSHAFT FITTED
NEW CAM FOLLOWERS
NEW HIGH PRESSURE HIGH CAPACITY OIL PUMP
VERNIER ADJUSTABLE DUPLEX TIMING GEAR ASSEMBLY
MODIFIED TIMING CHAIN COVER TO ACCEPT DUPLEX GEAR ASSEMBLY
CRANKSHAFT
CRANKSHAFT IS REGROUND LIGHTENED & BALANCED ALSO NITROCARBURISED (TUFTRIDED) WHICH IS A TWO PART CASE HARDENING PROCESS GIVING ULTIMATE STRENGTH MAKING THIS IDEAL FOR RALLY AND COMPETITION USE
NEW MAIN BEARINGS AND BIG END BEARINGS AND THRUST WASHERS
STEEL CENTRE MAINSTRAP FITTED
CLUTCH
LIGHTENED AND BALANCED CLUTCH ASSEMBLY
GEARBOX
UPRATED 4SPEED 4SYNCRO MANUAL GEARBOX LATER ROD TYPE
CENTRAL OIL PICK UP PIPE FITTED
X-PIN DIFF FITTED
3.4 FINAL DRIVE FITTED
ALL NEW BEARINGS GASKETS AND OIL SEALS FITTED.
#2 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 21 January 2013 - 01:29 PM
cylinder head -
CAMSHAFT
NEW CAM FOLLOWERS
CRANKSHAFT
CLUTCH
GEARBOX
X-PIN DIFF FITTED
#3 Noah
Noah
  • 4,136 posts
Can read it now....
#4 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 01:44 PM
Can read it now....
Cheers mate ;-)
#5 Noah
Noah
  • 4,136 posts
Posted 21 January 2013 - 01:45 PM
I'd say get the roller rockers, +40 thou is 1312cc? Correct.
If your building an engine of that caliber then 1.5 Ratio Roller Rockers will be a good add on, especially with the 276 cam
So I say yes. Get them.
#6 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 01:48 PM
Cheers for that, yes 1312 cc, I shall add the rockers too now mate ;-)
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 21 January 2013 - 02:37 PM
who is building the engine for you?
#8 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 02:54 PM
Its from a seller on ebay, here is a link to one of his engines, he has others for sale on there too, It seems he has had some good positive feedback from previous customers. http://www.ebay.co.u...984.m1423.l2649
#9 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 04:50 PM
I am looking for some parts to help with the auto - manual conversion,
I am in need of a complete rod type gear selector and complete gear linkage and a clutch pedal with spring or a complete pedal box, all must be in good condition,
was thinking for the price that i may as well buy the clutch master & slave cylinder brand new, also the braided clutch hose and manual engine steady i think i shall buy new, I have a new manual subframe ready and waiting for the conversion.too,
Is there anything i need that i may of missed out to complete the conversion.
#10 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 January 2013 - 05:01 PM
why not use the auto to manual engine mounts, saves the hassle of dropping the frame out.
I have a gear linkage setup complete, but would be looking for about £35 for it as they aint cheap when you need one.
Jordie
#11 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 05:32 PM
Jordie
Cheers Jordie, I have thought of the idea of using the auto sub frame with the mounts, I may do this and sell the new manual sub frame i have,
As for the gear linkage setup I will take it mate if its complete and in good condition, PM your paypal details and i shall send you payment mate
#12 Cooperman
  • 23,218 posts
Posted 21 January 2013 - 05:47 PM
That sounds like a good engine specification.
With regard to the 1.5:1 roller rockers I know they don't give much improvement in a car with a much 'hotter' cam like a 286, but they will probably give a more worthwhile improvement with a 276. You could gain, maybe, 3 bhp at over 5000 rpm, but will lose a bit of bottom end torque.
You do need good carburation with that spec and either an HIF44 or a pair of HS4's would work well.
Exhaust needs to be either a freeflow 3-into-1 or LCB manifold and a 1.75" int. dia exhaust system.
I hope this helps.
#13 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 05:52 PM
I hope this helps.
Yes thankyou very much for the advice Cooperman, I have also purchased a new hif44 setup to suit so i shall see how it goes with that mate, Thanks again
#14 Cooperman
  • 23,218 posts
Posted 21 January 2013 - 06:08 PM
You will find that it will run very well like that, but you might want to consider a distributor with a different advance curve from standard. Eith a programmable one or an Aldon 'Yellow' would do well.
You should get some very useable power and good mid-range torque as well. Enjoy!
#15 leeuk
leeuk
  • 681 posts
Posted 21 January 2013 - 06:14 PM
Thankyou very much for the advice mate its very much appreciated, I shall definitely have a look over the forum and have a good read up about the options given for the distributor ;-)
