A Panel Replacement Cost ~£500?
#16
Posted 20 January 2013 - 04:43 PM
#17
Posted 20 January 2013 - 06:19 PM
Remember garages are charging £50 to £120 an hour, depending on overheads. To spray the metallic and clear, probably going to need an oven or facilities for water based. Not cheap to buy/rent
#18
Posted 20 January 2013 - 06:20 PM
Then there's the cutting, trimming up followed by welding and grinding. The A post stiffener would also need to be done as part of this process. A panel welded on, paint prep then paint, followed by door alignment. So at a guess at least two days work.
#19
Posted 20 January 2013 - 08:01 PM
#20
Posted 20 January 2013 - 08:07 PM
If the flitch has gone especially up to the fresh air vent and beyond its not a five minute job. Carpet out, insulation out, trim out around the fresh air vent out,fresh air vent out, (this all depends on what dash is fitted of course??) A panel off, A post stiffener off then onto the flitch.
I've got a walnut dash which needs to having the steering column removed I believe. He said it would take him roughly three weeks.
Also in addition I spoke to my Dad who picked the car up and the mechanic said that he could probably do it as an inside job without touching the exterior?
So he wouldn't be fixing/replacing the A frame at all.
Just the flitch.
So is it a rip off getting just the flitch fixed costing £500?
#21
Posted 20 January 2013 - 08:14 PM
#22
Posted 20 January 2013 - 08:29 PM
Can you take pictures of the A post with the door wide open and also a picture of the flitch area in the inner wing both at the bottom and at the top where it goes under the scuttle close out.
#24
Posted 20 January 2013 - 09:26 PM
Needs the a-panel ripping off, a-pillar work, flitch work, surrounding areas blasting. New a-panel, new paint and underseal under the wing. Good time to inspect the scuttle and pump waxoil in the scuttle corners.
In my opinion £500 sounds about right for a small garage. but make sure it's done right! they very often aren't.
#25
Posted 20 January 2013 - 09:36 PM
looking at the photos, you've caught it just in time.
I'm going to run it up to my local mini specialist on Monday and have them look at it.
The car only cost me £1400 so I've got quite a few squids left to cover the cost.
#26
#27
Posted 20 January 2013 - 09:42 PM
Judging by the internal pictures the dashboard will have to come out as they rust will have spread further up. Pain in the backside but at least then you will cover everything. Don't be tempted to ignore it as it will come back and bite you later on with possible water leaks.
We do have a water leak at the moment, water comes off the tired and through the rusted hole bit (technical term) it soaks the floor, I have treated the rust on the floor and Waxoyaled it and the guy checked the rest of the car and the floor is fine. On a plus note both subframes are fine, there are no causes for concern underneath the car (was also waxoyaled by previous owner) the sills are also new just not fitted very well.
#28
Posted 20 January 2013 - 10:27 PM
There are plenty of people here who will be only too pleased to give welding advice to a beginner.
#29
Posted 21 January 2013 - 12:12 PM
500 is really not bad for the whole thing, if it was the only a panel then its pure madness LOL
#30
Posted 21 January 2013 - 12:42 PM
