Gradual Resto Of Our Ritz! Part 2!
217 replies to this topic
#31 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 09 March 2013 - 08:03 PM
Well today dad and I started on the passengers floor, so Started by taking out the seats carpets and other bits and bobs, and also the dash.
We were going to just replace the front floor, but as you know minis always surprise you!
Both front floors are dented where they've been jacked up on.
In the rear bit of the floor there was a "bit" of rust that we could see under the bitumen. So we chipped a bit off. >_< Most of the rusty holes had been "repaired" with some seam sealer squirted in :thumbsup:
Turned out it was quite rusty :ohno:, So I went over to the drivers side where there was a bit of black sticky stuff (like on the inside of quarter panels have), so I thought must be covering a patch, I was wrong ...
Thats right a stanley blade, No need to weld when you use them ;D
So we took all of the bitumen off, I found the best way to give it a couple of sharp hits and get a chisel/scraper under it and it'll come off in large chunks.
Front floor with a few patches.
Drivers side
nice hole in the rear bench.
Passengers side
Nicer hole in the rear bench :mmkay:
So we set about repairing it.
Cut it out.
New peice made (crap photo)
Wire brushed and painted in my favourite colour :proud:
and welded in.
Wasn't expecting all of that really :geek: , but it'll get cut out and new welded in.
Any comments welcome.
Alex
#32 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 09 March 2013 - 08:10 PM
OMG i can't believe it that looks bad i can't believe that stanley blade! Poor Lulu. Hope she is ok.
#33 solihullian
solihullian
  • 82 posts
Posted 09 March 2013 - 08:24 PM
blimey, i hope that car was cheap considering how much rust it has................ >_<
#34 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 09 March 2013 - 08:26 PM
blimey, i hope that car was cheap considering how much rust it has................ Posted Image
It was to them but not when i paid £2500 for it!
#35 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 09 March 2013 - 08:29 PM
Has it got oversills on by chance??
#36 alex-95
alex-95
  • 6,078 posts
Posted 09 March 2013 - 08:35 PM
Compared to some it's not that bad, I'm glad I enjoy welding :thumbsup:, It also needs a patch in the boot and also the front panel.
#37 alex-95
alex-95
  • 6,078 posts
Posted 09 March 2013 - 08:37 PM
Yep, and they will be staying, on the passengers side the original one had been taken off then that welded on, not sure on the drivers yet.
#38 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 09 March 2013 - 08:39 PM
That's your choice however you have already cut two patches out of the inner sill so i will put money on there will be more rust under there somewhere.
#39 alex-95
alex-95
  • 6,078 posts
Posted 09 March 2013 - 08:45 PM
I'm sure there will be more but I don't think it's "that bad". We're just trying to get it back on the road again. It'll be stronger that it was with the rust and seam sealer anyway.
#40 grahama
grahama
  • 2,442 posts
Posted 09 March 2013 - 09:41 PM
Lovely neat patches Alex, but I have to agree with Sonik, you will probably have more problems in the near future and will be better taking them off and having a damn good look. If you put them back then up to you but would be a shame to finish and have rust quickly again.
Graham
#41 alex-95
alex-95
  • 6,078 posts
Posted 09 March 2013 - 10:20 PM
Graham
Cheer's graham, the patches went in very well. If it was a proper project with a full strip down etc then we probably would, But we don't have enough time and it's on a budget, for the time being it'll do :D .
Alex
#42 alex-95
alex-95
  • 6,078 posts
Posted 17 March 2013 - 09:27 PM
This weekend we continued with the floors.
Cut out the rust where the stanley blade was.
New piece welded in.
Cut out the other bit of rust and made a new bit.
Welded in.
Cut out and welded in a new piece by the rear bin.
Cut out the passenger side rear seat corner.
and welded in new.
Then the other side.
We also welded the sill to the passengers side repair that we did last weekend and gave it a paint. We still have to grind most patches down.
#43 alex-95
alex-95
  • 6,078 posts
Posted 24 March 2013 - 06:52 PM
Todays work.
Rust on the front panel.
cut it out to reveal the rust behind it.
Made a new peice out of card
And cut out of metal and bent it to shape.
Cut out the peice behind, made a new peice and tacked it on.
Fully welded
And a bit of a grind down and coated it in kurust.Posted Image
While I was doing that Dad was cutting out the rest of the rust in the back drivers side floor.
Took a while to do it as the brushes in the grinder broke.
We should be able to make a new peice and weld it in this thursday, as well as the other front bit that I made.
Alex
Edited by alex-95, 24 March 2013 - 06:53 PM.
#44 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 24 March 2013 - 07:14 PM
Blimey you sure are getting stuck in! I miss lulu! :cry:
#45 alex-95
alex-95
  • 6,078 posts
Posted 24 March 2013 - 08:25 PM
Yep, need to, Not long till riv Run and have a few more bits to do, Hope its ready O_O.
:whistling:
