Gradual Resto Of Our Ritz! Part 2!
217 replies to this topic
#196 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 07 July 2014 - 07:54 PM
Wow you have done a lot to her of late great work! I was 2 cars behind you yesterday on my way back from McDonalds was nice to see her driving.
cheers mate.
Last weekend we stuck the vynl door covers to the plastic backings that I cut out (page 9).
Then on saturday we went to a local steam rally where the mini got a bit muddy and found this on the windscreen >_<
 and yesterday we went leak finding again as when I washed it there was some water coming in. I thought it was the door check strap but was still coming in, so sealed up the bottom of the a-panel and doorstep but it still comes in :mmkay:
#197 alex-95
alex-95
  • 6,025 posts
Posted 17 August 2014 - 07:45 PM
After driving around with just 2 caps on for a while, I fixed the other two hubcaps by using cable trunking cuting and bending and glueing. one cap was an original with 2 tabs remaining and the other the one below, it needed a bit more bending than in the pics to stop it moving but they're quite hard to get off now :lol:
I made a boot board to out of the corrugated plastic, just needs to have a bit of carpet put on it.
#198 alex-95
alex-95
  • 6,025 posts
Posted 31 August 2014 - 07:44 PM
on Thursday I removed the sealed beam headlights, wireing and metal bowls, 1. because the sealed beams aren't as good as the halogen and 2. the metal bowls were a bit rusty. I knew they were rusty when I took them off for welding the front, so have improvised for a while using some sealent and a bit of plastic :genius:
the rubber bits for adjusting screws had perished and broken, I had to fix them, I had some spare rubbers that had perished and cracked on the ring so cut it up and stuck them onto the original ones.
soldered the side lights on (rather than using a block connector and twisting one of the wires together like the previous owner of the the lights did >_< )
And all back together with plastic headlamp bowls, I did have a problem fitting a headlamp ring but a bit of cutting solved that :whistling:
I much prefer the yellow lucas covers but since it's starting to get dark I thought it'd be better to be able to see :lol:
#199 minimuk
minimuk
  • 1,946 posts
Posted 31 August 2014 - 08:13 PM
he does look ace Alex ;D
#200 alex-95
alex-95
  • 6,025 posts
Posted 31 August 2014 - 08:45 PM
she ;D  cheers :D
#201 alex-95
alex-95
  • 6,025 posts
Posted 21 September 2014 - 08:09 PM
Last weekend we done a couple of bits to Lulu, First off I replaced the waterpump.
Then we replaced the Side window rubber as we had put sealent around it to stop the water coming in, this is what we found when we cut the old rubber off, which was hard and perished.
So gave that a good wire brush and a couple of other areas and painted it, Then after fitting the rubber 3 times in different orientations, we put some string in the rubber and refitted the window.
Then I fitted the seats that I bought for my project mini as we're going to castle combe next saturday,  here alot more confy but slightly higher and further fowards so you're not in such a good driving postition :lol:
We also found what we think is where the water is coming in, just on the top of the a-panel, so took off the arch and seam strip to which we found a bit of rust, sealed the hole and painted the seams, just need to lacquer the seam strip and refit it.
And yesterday I replaced the teardrop mount again as it had split again, had to make a washer to fit between the subframe and mount so hopefully it wont split again.
Alex
#202 josh.goddard
josh.goddard
  • 398 posts
  • Local Club: Derbyshire Classic Mini Club
Posted 22 September 2014 - 11:09 AM
Nice to see it's still getting the love and attentions it needs
#203 alex-95
alex-95
  • 6,025 posts
Posted 22 September 2014 - 08:21 PM
Cheers.
I found out today I had a faulty brake light so this evening we went fault finding, tested the fuse all fine, took off the wires for the brake light switch and joined them together and the brakes lights come on, so cleaned the terminals and they work again :thumbsup:
#204 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 30 September 2014 - 09:41 AM
Haven't been on in a while but nice to see her again and keep up the good work.
#205 alex-95
alex-95
  • 6,025 posts
Posted 30 September 2014 - 08:07 PM
We made it up to castle combe and back without any problems. :D
#206 alex-95
alex-95
  • 6,025 posts
Posted 07 December 2014 - 09:18 PM
Theres not that much that has happened to the ritz lately, We went to a meet at capt'n jaspers in plymouth, all went well ... on the way.
On the way back when driving around with a few others it died >_<  We managed to get it going after about 15 minutes by removing the electronic ignition, When we got home we found a fried transistor so stuck another one on as it's a kit from maplin.
10353723_895810790432234_771167131240329
And today I changed over the radiator (stolen from the sprite) and bottom hose as the other had a small leak. I've got to fit new front and rear screen rubbers as the front leaking, I'm going to replace the screen to as this one has a chip on it.
#207 alex-95
alex-95
  • 6,025 posts
Posted 26 January 2015 - 08:55 PM
Spent most of the weekend on the ritz doing a few jobs. First up was replacing the windscreen, It was leaking in a corner and there was a bit of rust.
Popped it out on thursday night. Much more fun driving without a windscreen :lol:
bit more rust than I thought, so chopped out the lips and welded new back on.
Rubbed down and rust treated it then primed it. Done both sides as the other side was a bit rusty.
Then rubbed it down some more and sprayed it with the rover siver leaf rattle can which turned out pretty good. With help from dad last night we managed to get it fitted it again, we used tyre lube to fit the seam locking strip which made the job alot easier.
A while back we made our own tool out of an old screw driver cut down, a round bit of steel drilled to the size of the screwdriver shaft welded to it, a bit of bent wire and a grub screw to hold the wire. oh and a bit of heat shrink.
While the paint was drying I drained the coolant as the stuff I had in it was wrong. so Flushed it through and refilled with the blue stuff. Fitted proper weather shield brackets (thanks to megamini_jb for the clip).
I also replaced the door rubbers and repainted the wiper arms as there was a chip (paint ;D) on one.
#208 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 26 January 2015 - 08:58 PM
Good looking project bud!
#209 alex-95
alex-95
  • 6,025 posts
Posted 26 January 2015 - 09:23 PM
Cheers mate :-)
#210 alex-95
alex-95
  • 6,025 posts
Posted 18 April 2015 - 08:33 PM
Not much has been happening to the ritz lately, Gave it a check over last sunday, greased the nipples etc. I resealed the exhuast where it goes from 2 into 1 as it was blowing a bit and turned the clamps 90 degrees so they don't catch on speedbumps again. Then yesterday was MOT day, had to fix the fog light as the connections were dirty, so with that all done it was ready.
And she passed :gimme: with 5 advisories  :highfive:
