Gradual Resto Of Our Ritz! Part 2!
217 replies to this topic
#181 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 15 April 2014 - 06:35 PM
And she passed! :w00t:
There are a few things we need to look at like the some surface rust but thats not too bad.
#182 minimuk
minimuk
  • 1,946 posts
Posted 15 April 2014 - 07:22 PM
Get In.....well done bet yr happy ;D
#183 alex-95
alex-95
  • 6,025 posts
Posted 19 April 2014 - 08:16 PM
yeah very happy with it :D
decided to degrease the sump a bit yesterday to try and find where the oil leak is coming from, I got a bit carried away and degreased the front of the engine too, revealing the lovely yellow paint :D
#184 minimuk
minimuk
  • 1,946 posts
Posted 19 April 2014 - 09:26 PM
were is the wet area,....follow the trail upwards ;D
#185 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 22 April 2014 - 08:42 AM
Great news you actually drove past me the other day it broke my heart!lol I really want another mini.
#186 alex-95
alex-95
  • 6,025 posts
Posted 22 April 2014 - 08:49 PM
when was that then? were you in your car? :shy:
#187 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 09 May 2014 - 11:26 AM
I can't remember what day but I was parked up by Fitzgeralds up walker lines ind estate in a red reno scenic. It was lovely to see her go by but broke my heart. Did you go Riv Run? we were there.
#188 alex-95
alex-95
  • 6,025 posts
Posted 10 May 2014 - 01:46 AM
Oh right, I was getting a new auto advance pipe for it as the rubber end snapped >_<. We did but left around 10.45 and didn't go in lulu, she's got a rattle which we think is the idle gear bearing, thrust bearing or timing chain, so thats another job which may require the engine to be taken out. O_O
#189 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 10 May 2014 - 08:50 AM
Dad fitted this light reminder, If I leave the lights on it'll beep and light up when i open the door, very handy as I'm likely to do this :lol:
where do i get one of these from?????
and how does it fit?????
#190 alex-95
alex-95
  • 6,025 posts
Posted 10 May 2014 - 01:41 PM
I got it from ebay, type in something like "light reminder", Around 5 pounds I think. it has 2 wires orange and green, one goes to the light switch and the other goes to the door switch, I can't remember witch way around it goes though. the intructions on the back says which way though. they wire it differently too, they put it on the ignition IIRC.
#191 alex-95
alex-95
  • 6,025 posts
Posted 08 June 2014 - 08:17 PM
So friday I brought lulu into the garage and started stripping the engine bay down, taking out the rad, alternator etc and draining the fluids. then yesterday I had the morning in the garage trying to get the y peice manifold part off the exhaust ...  with no luck, so Dad did that when he come home ( we now need to repair the 2 into 2 exhaust part :lol:. Then today I set about splitting the bottom ball joints, the drivers was quite easy but the passengers wasn't at all, in the end we used the hammer in type fork splitter rather than the type with the bolt. so then this evening we got the engine out.
found where the oil leak is coming from.
thats about the good pictures I got, the rest are just of where parts go. I did clean up some parts ready for painting like the starter motor slave cylinder bracket and radiator bracket. Tomorrow after work I'm planning on degreasing it so there may be an update tomorrow, We're hoping to get the parts on friday to replace the bearings and that.
Alex
#192 alex-95
alex-95
  • 6,025 posts
Posted 26 June 2014 - 09:01 PM
Last week Dad and I started work on the engine, Dad gave it a degrease and clean and we started removing the clutch and removed the second casing and timing cover. on friday we took off the gearbox, inspected it and replaced the idler gear bearing then refitted it.
then we moved onto the other idler bearing, this is how we did it:
Knocked out the rollers and cage by sticking screwdriver between the cage and bearing body.(imagine it's in the casing)
Then got a longish bolt, a thick washer which we cut the sides off to the size of the holw
it can then be put on the bolt and slid into the the bearing.
then get a plate/bar to got over the caseing and wind the nut with a few washers onto it, you may need to put a spacer in like my pic.
then we started cleaning the engine bay.
dropped the subframe
couple of bits of rust on the inner wing
which I cut out and repaired.
Dad wirebrushed and kurusted it and sprayed it with zinc spray and I painted it with silver hammerite.
we fitted a new oil pump
and painted the engine with yellow hammerite.
and then we fitted the bits that I painted black.
I had to weld up the diff exhaust bracket as it cracked
Then we set about changes the front brake pipes as they were perished, which was made easer by having the engine out.
so then we refitted the engine and I fitted all the parts.
I forgot to fit the gearstick rubber (again, see the bottom of page 1 :lol:), the old one only lasted a year, it had split on every squashy bit.
so sunday evening we got her running and monday night we fitted the bonnet and other bits
Then as we had trouble getting the manifold off the 2 into 1 bit we had to make new pipes to fit as the others were mangled. We done this with some 1.5mm sheet and bent it around a bit of ali pipe we had that was the perfect size, cut it to length and got the circumference right and welded them onto the 2 into 1 pipe, which I think they turned out quite well, unfortuanly I was welding pretty much blind as our auto dimming mask didn't work so had to use the hand held one with the dark glass. we fitted the manifold to the engine first and test fitted it a few times before welding the pipe on on to make sure it was right to be able to slide in each other.
so sunday evening we got her running and monday night we fitted the bonnet and other bits and had a quick test drive which went fairly well apart from the speedo not working and I think a spanner that I made which fell down the back of the engine after just making it >_< fell off the car while driving. So tuesday we undone the speedo cable to find I hadn't fitted it correctly so we fitted a new cable and works perfectly now.
then dad was reading a book and noticed that the oil pressure light should come on when the ignition is turned on, it hadn't done this in our ownership or a couple of years before that i'd expect. so traced it down to be te pressure switch it's self after removing the speedo (again  due to the speedo cable) luckily our local motor factors could get one to us that day so fitted that and
we have a light :D
It's good to be able to drive again after getting lifts to work for a few weeks.
It's not in exact order due to photobucket liking to muddle up my photos, but it's roughly in order.
cheers Alex
#193 minimuk
minimuk
  • 1,946 posts
Posted 26 June 2014 - 09:11 PM
nice one love the fabrications, carry on all be good in the end for sure ;D
#194 alex-95
alex-95
  • 6,025 posts
Posted 27 June 2014 - 08:09 PM
cheear mate, we should be doing the doorcards for it tomorrow to get it looking a bit better for some local rallies as it just has 1 black passenger door card in at the moment :lol:
#195 lulu85ritz
lulu85ritz
  • 1,308 posts
Posted 04 July 2014 - 11:41 AM
Wow you have done a lot to her of late great work! I was 2 cars behind you yesterday on my way back from McDonalds was nice to see her driving.
