Whats the best way to clean up aluminum engine castings? I want to clean up the outside of the transmission and all the aluminum on the outside of the engine. Hopefully get it close to looking like new. It is all disassembled so that might make things easier. Whats the best and easiest way to do this?
Best Way To Clean Aluminum Engine/tranny Parts.
Marlin
, Jan 10 2013 03:01 PM
7 replies to this topic
Posted 10 January 2013 - 03:01 PM
Posted 10 January 2013 - 03:10 PM
Try Bead blasting, then seal with a clear lacquer to prevent oxidation.
Posted 10 January 2013 - 03:11 PM
Sorry should have said need to strip parts down to bare aluminium first.
Posted 10 January 2013 - 03:13 PM
strip down to bare aluminum and boil the parts in lemon juice. best way to clean aluminum parts. if that cant be done use hot lemon juice to scrub it with and let it soak
Posted 10 January 2013 - 03:16 PM
from this
to this
just a wire brush in a drill works quite well
to this
Edited by Bungle, 10 January 2013 - 03:19 PM.
Posted 10 January 2013 - 03:50 PM
Best way to clean ali casings....
1. Put ali casing in chemical dip tank....
2. Put kettle on and have tea
3. Remove from dip tank.
4. Pressure wash all DGS, Paint, Gaskets etc off casing
5. Put in Hot Parts washer ( aka Dishswasher )
6. Put kettle on again !
7. Empty dish washer, while parts are still hot and slightly wet, remove any remaining gasket silicon etc etc
8. If you're not satisfied with how clean items are.... Plug all threads & holes with bungs or grub screws.
9. Blast with medium grade grit to remove any oxidation, remaining gaskets
10. Blast with fine glass medium to rejuvenate ali, and shine.
or...
http://www.guess-wor...arbox/strip.htm
or...
Posted 10 January 2013 - 04:37 PM
I have a dishwasher in the garage for this purpose - works a treat.
Have to make sure it is a base casing though, the gears don't like it much...
Posted 10 January 2013 - 05:05 PM
WD40 and scotchbrite, does no damage and brings it up a treat.
