Gears In 1St And 2Nd Clonking When Putting It In To Gear Hayabusa
9 replies to this topic
#1 joss
joss
  • 143 posts
Posted 09 January 2013 - 01:07 PM
Hi any ideas on how I can resolve this issue
#2 R1mini
R1mini
  • 1,387 posts
Posted 09 January 2013 - 01:13 PM
Seems to be a common problem with bike engines in cars, bikes do the same but they have a rubber cush drive behind the rear sprocket which cushions the noise and clonk considerably.
I would look at the clutch adjustment and do some fine adjustment to make sure the clutch is not dragging as you put it into gear
David
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 January 2013 - 03:59 PM
Common with bike engines just listen to any Jap Bike going into gear and you will hear it.
#4 joss
joss
  • 143 posts
Posted 09 January 2013 - 06:31 PM
How would I go about carrying out any adjustmens to the clutch
#5 R1mini
R1mini
  • 1,387 posts
Posted 09 January 2013 - 07:15 PM
I believe the zcars hayabusa uses a stop under the mini clutch peddle, it should be a bolt which should be adjustable, things change on the zcars minis so this may not be the case with your car
David
#6 ZCars Steve
ZCars Steve
    Z Cars
  • 141 posts
Posted 10 January 2013 - 12:34 PM
David
this is to stop the clutch opertation from pushing past the seals if you have the 14mm master cylinder (which i think you have Joss) there is no need for the pedal stop
#7 edsmini
edsmini
  • 357 posts
Posted 10 January 2013 - 01:43 PM
Joss,
is it only doing it when you first put it in gear, or is it when you change from first to second?
Ed
steve is correct you do not need the pedal stop.
#8 joss
joss
  • 143 posts
Posted 10 January 2013 - 06:33 PM
Hello Ed
Mainly first gear but i do have one other question in second gear I get a sound from the diff or gearbox that sounds like a clonking cv joint but it only occasionally.
#9 edsmini
edsmini
  • 357 posts
Posted 10 January 2013 - 09:51 PM
They do clunk when you put them in first gear, you can feel the car jolt slightly when you engage first gear.
Is the chain tensioned properly? A loose chain can give weird noises. I'm sure Stuart that had the car b4 you had fitted new cv joints at the rear. I would have to see the car to help any further joss, I'm clasping at straws ;-)
Spend an hour with a spanner, and check all the rear bolts, check the arms for any sideward movement, the bolts for the trailing arms take quite a bit of tightening.
The diff can make a clunking noise if you go sharp left then sharp right, this is the plates in the diff working as they should.
Cheers,
Ed
Like the new rims, hurry up and get them fitted ;-)
#10 joss
joss
  • 143 posts
Posted 12 January 2013 - 10:26 PM
Hi Ed seen the rims?
