Rocker Cover Bolts
5 replies to this topic
#1 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 03 January 2013 - 12:15 PM
i,m fitting an alloy rocker cover but the bolts are too short.
can you get longer ones, preferably chrome.
#2 [email protected]
[email protected]
  • 23 posts
Posted 03 January 2013 - 01:05 PM
Take a look at these on eBay, not sue about the length problem though. You could always go for T-bars.
#3 mattbeddow
mattbeddow
  • 336 posts
Posted 03 January 2013 - 05:09 PM
Are you sure they are too short or do you have the wrong studs for your rockers? With the cover off, the two outer studs should be almost an inch longer than the middle two (note im talking about the rocker studs not the head studs)
#4 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 03 January 2013 - 06:18 PM
the alloy cover is about 1cm taller than the original, combined with a new gasket and the bolts don,t quite reach.
#5 tiger99
tiger99
  • 8,584 posts
Posted 04 January 2013 - 12:53 PM
It may be easier to find longer studs than longer "bolts" as the bolts are rather special with a female thread. The studs are just plain 5/16" UNF grade 8.8.
#6 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 05 January 2013 - 12:23 PM
many thanks, i,ve found some longer bolts at minisport.
