Cylinder Head Surface
Posted 28 December 2012 - 11:33 AM
I assume these are water ports.
Is this serious damage ? Will it cause any problems in the future ?
Elliott
Posted 28 December 2012 - 12:32 PM
Posted 28 December 2012 - 12:37 PM
Posted 28 December 2012 - 12:42 PM
Get the seller to refund you and find another head:).
Posted 28 December 2012 - 12:46 PM
Posted 28 December 2012 - 12:54 PM
I think you're referring to dry decking. Unfortunately this is not dry decking. It appears it has been over skimmed and broken the surface between the two holes.That may be a mod some people do to the cooling system. They block off some water galleries in the blog and head and re route them. I think this is hat this could be but I wouldn't use that head. Not been done right.
I have contacted the seller about a refund, but I wont name him unless circumstances change.
Elliott
Posted 28 December 2012 - 12:56 PM
Posted 28 December 2012 - 01:00 PM
Posted 28 December 2012 - 01:01 PM
Posted 28 December 2012 - 01:31 PM
If you can, post a photo with the gasket aligned to the head, another with it on the block, and another with just the block. That will give a better idea and people may have more advice.
I know that if certain heads are skimmed too far, an oilway is broken into and is generally repaired by brazing in a piece of copper tube, and then lightly skimming again. However, this seems to be a waterway, as people have suggested.
Posted 28 December 2012 - 01:54 PM
you can check yourself using water and a pipette or easier to ask the seller what the mods are for
Posted 28 December 2012 - 02:50 PM
It is not ideal, and should be replaced by the supplier, but in reality that damage is unlikely to cause a leak, unless it overlaps on to some hole other than a waterway in the block. There would seem to be more than enough metal still around to form a good seal as long as the gasket has something solid behind it in the block.
Hard to tell from the pic how much that has been skimmed, the chambers do look shallow but hard to be exact in 2D. Did the seller say what the chamber capacity is?
The chamber CC was quoted to be 16cc. I believe standard are 21cc.
The actual ad is still in the for sale section to view if necessary.
However I don't want to put all the blame on the seller at this time. It could be a genuine mistake, so I will wait for a response from the seller.
Elliott
Posted 28 December 2012 - 03:51 PM
Best to have it welded up and reskimmed if you are keeping it.
Posted 28 December 2012 - 04:01 PM
it looks from the pictures that there will be decent gasket overlap all round so it might not leak. However the gasket you are using has copper rings around these holes, which is normally a good thing, but in this case not helpful as the holes extennd beyond the rings. A plain gasket with no rings would, in this instance, work better.
Im hoping the seller will refund first, but getting it welded will be the next option. Do you have an idea how much it will cost to get it welded ?
Elliott
Posted 28 December 2012 - 04:12 PM
