Black Ugly Mini Cooper Rsp
194 replies to this topic
#106 roughneckin
roughneckin
  • 109 posts
Posted 31 October 2013 - 03:31 PM
 Did u find it fairly easy to do it flipped on its side? Did you overlap that piece a bit or no?
Easy to flip as the subframes are off. I supported one corner with a strap attached to roof.
I was worried about overlapping the panels as did not want water to run along the overlap. Saying that I did overlap by about 1mm to make the weld thicker. By doing this small overlap when I weld it the overlap disappears into the pool of weld.
Sounds like a plan!!  Thanks
#107 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 31 October 2013 - 07:07 PM
If you want tips on flipping your shell on its roof have a look at this Youtube vid.
#108 roughneckin
roughneckin
  • 109 posts
Posted 31 October 2013 - 11:45 PM
If I worked that fast the mini would be done already!! JK!! Great way to flip it and makes the work simple without a spit. Thanks.
#109 rally515
rally515
  • 3,848 posts
Posted 01 November 2013 - 06:20 AM
I had that idea for Tom2012's mk1 project! haha, would love his workshop in that video, very big, smart and clean :w00t:  :thumbsup:
#110 phil hill
phil hill
  • 616 posts
Posted 01 November 2013 - 08:48 AM
I like his subframe dollies, very neat idea that !!
Phil.
#111 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 01 November 2013 - 09:34 AM
what a guy! lol
#112 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 21 December 2013 - 04:14 PM
I got in the garage today and did a bit more grinding; passenger floor all sorted now.
Now need to flip the car onto its roof and start on the boot floor repair :)
#113 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 03 January 2014 - 04:23 PM
I cut off the rear valance to find 1 layer of metal where there should be 3 and the boot floor is not even attached.
I found where the spiders were living.
Cut the lower part of the rear panel out.
Welded in the repair and gave it a tickle with the grinder. I will give it a once over with the flap wheel and then move on to the center section and other corner. Once that is all done then its onto the boot floor repair.
#114 evilpen14
evilpen14
  • 115 posts
  • Local Club: CCC and RAF Mini Club
Posted 09 January 2014 - 10:40 PM
I wouldn't have a clue where to start there. Hope it goes well and we have some more pictures soon :)
#115 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 10 January 2014 - 04:40 PM
The hardest thing is finding the time.
I cut out the rot and weld in a bit. If its no good then I cut it out again. If the weld is ugly I grind it back; as long as the penetration is good you can fix it with more weld and more grinding.  ;D
#116 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 26 January 2014 - 09:01 PM
Pretty happy with how the repairs are going. Back panel is repaired with the 3 part repair panels so pretty cheap. The welds are ground back and given a dash over with weld-thro so no filler get. As you can see by the pics it will not need much filler.
The boot floor is also welded and I have started to grind it back. As you can see it only needed an inch or so so I am not sure if I will grind the weld back any more than this as it will be hidden by the rear valance. What do you guys think?
Still need to do a bit of hammering to straighten the floor and then I will spot weld the 2 panels together.I have good penetration so will need to tickle the weld inside the boot where it can be seen.
Edited by Wise Old Elf, 01 February 2014 - 10:20 PM.
#117 Dusky
Dusky
  • 5,322 posts
Posted 31 January 2014 - 10:22 PM
Nice to see the restauration progress! :)
BUT
May I ask what RSP means?
cheers!
#118 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 31 January 2014 - 10:43 PM
BUT
cheers!
Cheers Its getting there.
Rover Special Products
http://www.rsp-coope...out_the_RSP.htm
#119 domdee
domdee
  • 1,183 posts
Posted 01 February 2014 - 09:45 AM
build it up with paint like that fella doing the blue mpi shell does. avoids the the use filler
#120 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 09 February 2014 - 03:24 PM
