Black Ugly Mini Cooper Rsp
194 replies to this topic
#16 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 28 December 2012 - 09:30 PM
I will bet you a chocolate biscuit and a cup of tea that I finish first.
#17 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 28 December 2012 - 09:40 PM
LOL you have less to do but we will see. It will take you longer if I nick your engine.
Let me know when you are around these parts and I'll make you that cup of tea.
#18 Wigeon Incognito
Wigeon Incognito
  • 294 posts
Posted 29 December 2012 - 12:53 AM
Good luck from a fellow Essex RSP owner! Mine doesn't know it yet sitting happily in the garage but it's about to be stripped down too.
#19 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 29 December 2012 - 08:24 AM
I am near Colchester; where are you?
When I get to the reassemble I may need to look where everything goes as I did not take it apart.
#20 Wigeon Incognito
Wigeon Incognito
  • 294 posts
Posted 29 December 2012 - 06:04 PM
Not far away at all, I'm over near Braintree. If you do want to have a look at anything you're more than welcome although having seen a few of your posts I get a feeling you're a bit more mechanically capable than me - I'm learning though.
Edited by Wigeon Incognito, 29 December 2012 - 06:05 PM.
#21 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 29 December 2012 - 06:40 PM
You are just around the corner. I am a long way from finishing but will defo need your help later on.
I met a guy at the Marks Tey Mini show with a MINT red RSP who is in Feering but did not get his name or number.
I can fix most things on a Mini and my garage is pretty well equipped if you need anything let me know.
Jason
Edited by Wise Old Elf, 29 December 2012 - 08:31 PM.
#22 MrBounce
MrBounce
  • 2,643 posts
Posted 29 December 2012 - 11:50 PM
Oooh I love reading about a good weld-a-thon. This is the reason why I've got a fibreglass car as I can't weld! Maybe I should get another project and learn...
Am only just down the road (and over the border) in Ipswich. :gimme:
#23 Wigeon Incognito
Wigeon Incognito
  • 294 posts
Posted 30 December 2012 - 01:23 AM
Jason
Thank you very much, and that red one looks fantastic!
Matt.
Edited by Wigeon Incognito, 30 December 2012 - 01:33 AM.
#24 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 30 December 2012 - 09:22 AM
LOL I also have a plastic car but I am getting a bit bored by it.
#25 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 30 December 2012 - 01:08 PM
Ooh an élan8). Awsome cars! We run one built for the spa 6 hour. They sure can go when a little bit of money is spent on them!! :P
#26 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 January 2013 - 08:21 PM
A little progress on the shock mount. 1 skin done now to let the weld-through dry then I will weld the outer plate on.
Its a good place to start as I can play with the welder settings and no one will see it.
EDIT:
Just added a few more pics of the shock mount; as you can see the hole has now vanished and I have patched up the inner wing.
  • Attached File  1.JPG   81.77K   49 downloads
  • Attached File  2.JPG   74K   42 downloads
  • Attached File  3.JPG   74.38K   44 downloads
  • Attached File  $1.JPG   138.84K   24 downloads
  • Attached File  4.JPG   70.48K   33 downloads
  • Attached File  5.JPG   72.47K   35 downloads
  • Attached File  6.JPG   78.3K   44 downloads
  • Attached File  7.JPG   46.16K   39 downloads
  • Attached File  8.JPG   59.07K   23 downloads
  • Attached File  9.JPG   58.83K   45 downloads
Edited by Wise Old Elf, 04 January 2013 - 08:48 PM.
#27 Noah
Noah
  • 4,136 posts
Posted 01 January 2013 - 08:30 PM
Neater than my welding...
How non-existant was the shock mount?
#28 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 January 2013 - 08:43 PM
Remember the flap wheel is your friend.
The actual mount bracket has a small hole so I ordered 2 new ones. They arrived after 2 days over Christmas so will use those guys again.
http://www.ebay.co.u...984.m1497.l2649
Edited by Wise Old Elf, 01 January 2013 - 08:44 PM.
#29 Noah
Noah
  • 4,136 posts
Posted 04 January 2013 - 10:40 PM
You need to weld a Scuttle closing panel on both sides, you've painted over where its meant to be! LOL.
I think they're £6 a side, non-genuine.
#30 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 04 January 2013 - 10:48 PM
Yeah I have them but wanted to protect the metal as I am going to do the A post next. I will clean off the area when the scuttle goes on.
The scuttle is the easy part as I will use my spot welder on that.
The A post is going to be tricky as I want the door gap to be spot on.
The inner wing came out ok though. I spent a long time on it but you cannot see the repair and the flitch panel is now welded to the inner wing properly now.
All progress is good.
