Supercharger Kits
Posted 27 December 2012 - 06:37 PM
Vmaxscart:
uses a billet crank pulley to drive a separate belt to the charger. Is known to be a very good quality kit but he is some times hard to get hold of. He can also offer charge cooling for the charger/+10hp and does the heads.
Minispeed:
This kit uses a modern type serpent belt to drive everything. So in this kit you get new pulleys for everything. Its also suppose to be the most efficient to? Dont know how or why but they say it is. Service is very good but I've seen some reports for bad parts and poor quality.
Jonspeed:
Not much info on these but they look to be very much like the vmaxscart kit belt wise but you can't tell from photo's. However service is suppose to be very good as is the quality of the bits.
So which is the best and most efficient charger kit???? Are there any other kits and can any one give genuine first hand reviews of there dealings.
Many thanks in advance and I'll let you know more once i know it.
Chris.
Posted 27 December 2012 - 07:01 PM
Posted 27 December 2012 - 08:36 PM
but the Jonspeed kit is good a firend is using it and he can't fault it he just went to talk to them and had some bits dropped he used MPI pulleys so no silly extentions on the other stuff :)
Posted 27 December 2012 - 08:49 PM
Just my view but worth considering
Posted 28 December 2012 - 11:08 AM
Andy500, are you saying that the mpi mini's had the modern style belt??? And can these be retro fitted or would I need to buy a new waterpump and alternator???
Thanks Again,
Chris.
Edited by chris211083, 28 December 2012 - 11:12 AM.
Posted 28 December 2012 - 12:13 PM
Chris.
Posted 28 December 2012 - 12:17 PM
Posted 28 December 2012 - 08:54 PM
On my mpi the standard pulleys, I.e bini ( which was 68mm iirc) and mpi bottom pulley resulted in 18psi and charge temps of 115 degrees c! Vmaxscart do install a recirc pipe but the best and correct option is to get he pulley sizes correct. It was a few years go now but I had Jonspeed make me a bigger pulley to my spec, I think it was 74mm which slowed the blower down so I got the correct boost level. I halved the boost to just over 9 psi but only lost 2bhp and gained in torque. Which was because the charge temps dropped so significantly but would have still warranted an IC!
If you do install the m45 I would also consider a water injection kit (pre charger) if you go for a suck through config, will work wonders on charge temps as well as some other benefits. Although if its just on a daily which doesn't get the boot hat often I'm sure it would've fine without.
Good luck with it
Posted 29 December 2012 - 12:07 PM
Chris.
Posted 29 December 2012 - 12:42 PM
Posted 29 December 2012 - 02:25 PM
Minispeed:
Hi Chris, that's a good question with most of the suppliers prices being similar and all supercharger kits giving a power increase. Our kit really is the best on the market due to superior design and craftsmanship and while we do not normally reveal our trade secrets I think this is a good opportunity to see the main difference.
This is a photo of a BMW mini supercharger body mounted on one of our rivals inlet manifolds. You can clearly see the that intake charge (air/fuel mix) is squeezed into a tiny hole which creates unwanted pressure and temperature while massively restricting power output. http://www.facebook....&type=1
This is a photo of the same BMW mini supercharger body mounted onto our own inlet manifold. You can clearly see the massive hold matched to the supercharger output which is achieved by hand crafting tubular and sheet steel individually in house by our engineers. There simply is not a comparable quality item in the market that even comes close to the efficiency and power that ours produces.
http://www.facebook.com/photo.php?fbid=532404026783219&set=a.362102667146690.91977.191862994170659&type=1&theater
Posted 29 December 2012 - 09:38 PM
Posted 29 December 2012 - 10:49 PM
Andy
Posted 30 December 2012 - 10:19 AM
I'm going to try and log my ACT's at some point, problem is the inlet is so close to the exhaust manifold, heat from the exhaust could quite easily transfer to the inlet manifold...
Posted 30 December 2012 - 12:17 PM
Grahamxx, So it's worth putting a heat shield between the two manifolds then.
Has anyone made a heat shield???Pic's???
Thanks again,
Chris.
