Welding these areas will burn off any protection applied to both the prepared door frame and the inner lip of the new skin. I am thinking of using Sikaflex to bond the skin on. The plan is to apply a bead to the door frame, drop the skin on and bend the lip of the door skin over. It seems like a good idea in practice but are there any downfalls? Just to add, I am planning on welding the top of the new skin to the window surround and where it wraps around the top of the door, above the check strap. Also the area at the back of the door, above the catch.
I am trying to avoid welding at the bottom of the door where rust protection is of course, important.
Anyone any thoughts?
Pete
