Diglers New Project, A Rwd Mx5 Mini Estate!
370 replies to this topic
#256 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 31 May 2013 - 01:54 PM
Amazing build. As an owner of both an mx5 and a mini I cannot believe I didnt think of doing this myself :P
Colour wise it has to be BMC Poo Brown..
#257 leaky
leaky
  • 6,890 posts
Posted 31 May 2013 - 02:06 PM
Any of these would look cool!
Mini%20Clubman%20Estate%201972%20rear.jp
The top one is my favourite!
Edited by leaky, 31 May 2013 - 02:08 PM.
#258 digler
digler
  • 439 posts
Posted 01 June 2013 - 02:26 PM
Looking good, do you do your welding in a continuous line or in pulses?
I always pulse weld, i'll stitch a panel on and then weld differant areas at about 15mm at a time.
When i weld on a flat'ish panel i'll have a bucket and a rag with water to cool down the panel to stop any warping.
#259 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 01 June 2013 - 05:31 PM
On a similar note; what do you use to grind your welds flush? I use a flap disc on the grinder but they never seem to be flush?
Jason
Edited by Wise Old Elf, 01 June 2013 - 05:33 PM.
#260 digler
digler
  • 439 posts
Posted 02 June 2013 - 05:45 AM
I always pulse weld, i'll stitch a panel on and then weld differant areas at about 15mm at a time.When i weld on a flat'ish panel i'll have a bucket and a rag with water to cool down the panel to stop any warping.
On a similar note; what do you use to grind your welds flush? I use a flap disc on the grinder but they never seem to be flush? Jason
I use a sanding pad on a rubber backing plate, 36 grit worka a treat!
#261 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 02 June 2013 - 08:12 AM
Cheers I'll give it a go.
#262 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 03 June 2013 - 08:36 AM
This freshly painted and polished!
#263 digler
digler
  • 439 posts
Posted 04 June 2013 - 12:41 PM
Back end almost done!!
#264 digler
digler
  • 439 posts
Posted 04 June 2013 - 12:44 PM
H
#265 Baldspeed Racing
Baldspeed Racing
  • 1,191 posts
Posted 04 June 2013 - 03:37 PM
epic fab skills mate, proper good job there
#266 HAR:MINI:E
HAR:MINI:E
    Just On Tickover
  • 7 posts
Posted 05 June 2013 - 06:54 PM
must be so nice to have such freedom to concoct and fabricate any fiendish plans you want!! envy is an understatement, I wouldn't mind having some welding skills like that as well to be honest ha ha  :crazy:
beautiful work . . . . will be meaty when finished!
keep it up (sure you need no encouragement though;)
#267 digler
digler
  • 439 posts
Posted 09 June 2013 - 09:19 PM
Welding done:-)
Just so brackets to make for the front end.
Got all the front end bonded back together and the bonnet widened.
#268 olds_kool_lews
olds_kool_lews
  • 3,601 posts
Posted 09 June 2013 - 09:30 PM
Forget flora.... That is the only low fat spread i want! Lol
#269 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 09 June 2013 - 09:31 PM
Daaaaaaaammmmmnnnn sooooonnnnn
#270 Bungle
Bungle
    Original Spamster
  • 28,971 posts
wow that still looks like a mini , but with big wheels
