Diglers New Project, A Rwd Mx5 Mini Estate!
370 replies to this topic
#181 rids
rids
  • 670 posts
Posted 10 March 2013 - 11:19 AM
I am pretty sure mx5s are a monocoque, most things are nowadays as its a bit old fashioned to have a body and a chassis. but nether the less this will be an awesome project no matter what the numberplate says :)
Put into Google 'MX5 Power plant frame'
Ooooooh! Taught me something, that is very interesting and opens up a lot of possibilities.......
It is a very interesting car and a great car to base a kit on.
I am not sure I would call it a separate chassis but the 2 subframes are connected.
The chassis on my Elan +2 is referred to by the factory as a 'subframe'.
they did blatantly copy the elan for the mk 1 and the "chassis" do look similar.
#182 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 March 2013 - 03:52 PM
yes i see now
yes as long as you don't modify that you can do what you like to the body as it carries no points and keep the MX5's registration
although i might confuse the MOT man or a copper doing a PNC check :lol:
#183 digler
digler
  • 439 posts
Posted 10 March 2013 - 04:38 PM
Can i not change the name of the car on the logbook? If i was to keep it as an mx5 with the points for iva ive on changed the body, as long as i didnt change any more, brakes, suspention, steering i wouldn't need an iva test, then i could get a number plate from dvla to make it look like its on an old reg. The mini shell is a 80s shell so i could get a plate with W at the end.
#184 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 10 March 2013 - 05:00 PM
DVLA leaflet INF26 goes through it.
I think you have at least 8 points with the MX5 bits.
Edited by Wise Old Elf, 10 March 2013 - 05:06 PM.
#185 iTomKart
iTomKart
  • 351 posts
Posted 10 March 2013 - 06:50 PM
Digler, could you give me an idea of the width of the mazda from doorstep to doorstep?
#186 digler
digler
  • 439 posts
Posted 11 March 2013 - 11:14 PM
i'll have a check, but i'm sure it was just 30mm wider than the mini.
boot area coming on nicely!!
rear valance corners on
boot corners in
boot floor in, but the hole is for my exhaust if i put it in the middle, i'll make a plate bolt on top if i don't use it.
#187 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 12 March 2013 - 08:58 AM
mate your not working fast enough. we just want to see more and more!
#188 steven
steven
  • 1,195 posts
Posted 12 March 2013 - 10:23 AM
love this project ! cracking fabrication :thumbsup:
#189 Elliskwleisk
Elliskwleisk
  • 250 posts
Posted 21 March 2013 - 09:56 PM
Creativity and mechanics combined, absolutely brilliant mate keep us updated!
#190 hoody99
hoody99
  • 699 posts
Posted 23 March 2013 - 11:03 PM
That the shell fully fixed to the mx5 chassis looking great as said above we need more lol
#191 digler
digler
  • 439 posts
Posted 30 March 2013 - 01:31 PM
time for an update..........
not been too well over the last few weeks so progress has not been as good as i'd like.
first job was to sort out the fuel filler, when i cut the mx5 up i cut out the filler cap, so if i could use it i could, and i can!!
turned around after a little drive!!
then with it turned round i could start on the front
ive moved the fuse box that sat next to the brake servo inside the cab, i want the inner wings clear of wires and clutter.
#192 PetePinnington
PetePinnington
    Formally known as PPinno
  • 367 posts
Posted 30 March 2013 - 02:16 PM
This is insane! Will the standard front fit over or will it need a bit of work?
#193 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 30 March 2013 - 05:35 PM
I wont you to teach me how to weld and fabricate!!!!
#194 ajtom94
ajtom94
  • 138 posts
  • Local Club: DCMOC
Posted 01 April 2013 - 02:43 PM
TEACH ME YOUR WISDOM :w00t:
#195 Tupers
Tupers
  • 4,142 posts
Posted 01 April 2013 - 04:01 PM
Go on narrow a Fortec body kit for it. :D
