Buying A New Loom To Replace Old
Posted 25 December 2012 - 12:10 PM
Am looking at getting a new loom for my 1988 mini it has 2 clocks. Do I need to give you more information?
Just wondering a couple of things:
1. Where is the best place to get a replacement loom?
2. Is is possible to get a braided loom over a taped one?
Would really appreciate a load of help with this.
Posted 25 December 2012 - 12:53 PM
http://www.autosparks.co.uk/
Posted 25 December 2012 - 02:14 PM
Posted 25 December 2012 - 04:46 PM
Posted 25 December 2012 - 04:51 PM
Posted 25 December 2012 - 05:26 PM
Posted 25 December 2012 - 05:51 PM
Edited by skoughi, 25 December 2012 - 05:52 PM.
Posted 26 December 2012 - 04:25 AM
whats the difference between a chassis loom and main harness
The term loom and harness are used pretty much interchangeably.
The real difference is in the adjectives "chassis" and "main". The meaing can vary from car to car. However, in both cases, the terms chassis or main imply that the section of loom/harness is the part that is in the "core" of the wiring. For example, it is not likely to include things like the shorter harnesses that go to the headlights. Some cars have separate harnesses for the gauges as well. When in doubt, it is best to ask the vendor what is and isn't included so you are not surprised by what you find in the box.
Posted 26 December 2012 - 04:54 PM
Posted 26 December 2012 - 05:29 PM
Posted 30 December 2012 - 10:55 AM
Posted 30 December 2012 - 03:54 PM
where do i find the chassis number as well?
Well... that may depend on what number you are looking for and the age of your car. Early cars had a "body number" that was stamped onto a steel tag spot welded to the top of the slam panel near the bonnet latch. The VIN number (probably what you really want) was on an aluminum tag "screwed" to the top of the radiator duct on the inner left front wing. The VIN tag moved to the slam panel on later cars and I don't know if they kept attaching the body number or not.
Others with better knowledge will be able to tell you specific places to look for the VIN tag on later cars.
Posted 30 December 2012 - 05:59 PM
Posted 18 February 2013 - 08:47 PM
erm when you say slam panel can you explain in more detail, do you mean when looking in the engine bay the little aluminium tag on the left hand side??
Posted 19 February 2013 - 03:15 AM
The picture below is for a '72 Mini listed on Hemmings web site. The VIN tag is slightly to the left of the latch, the body number I mentioned is seen to the right, just in front of the alternator.
