Xenon / Hid Headlamps Etc
7 replies to this topic
#1 JustJack
JustJack
  • 87 posts
Posted 24 December 2012 - 05:44 PM
To be honest, i don't really get it,
The only thing i understand is the color i want is about 6000k, and i need something called a ballast!
are these possible? ive seen a few kits on ebay, one with new Lamps if you search ebay "Classic Mini Super Bright HID Xenon headlamp set" you will see them!
but i have no idea if they are 6000k, anybody have any kits installed or can recommend any? and what price am i looking at ? can i use the original headlamps with ballasts?
Would love something like this....
Many Thanks for any help
Stevie
As you can see below i may as well hold a candle out the window with my current headlights
Edited by JustJack, 24 December 2012 - 06:11 PM.
#2 sledgehammer
sledgehammer
  • 3,093 posts
Posted 24 December 2012 - 06:34 PM
http://assets.dft.go...d-headlamps.pdf
#3 shabir
shabir
  • 346 posts
Posted 24 December 2012 - 07:27 PM
i wanted HID but i found on here that not legal as stated in the above document. It basically tells you if you want HID you must have a e-marked lens, as the standard lens can cause glare with HID, also you will need self levellers for the lights and headlight cleaners.
#4 sledgehammer
sledgehammer
  • 3,093 posts
Posted 24 December 2012 - 08:37 PM
Maybe a better idea if we ask what is the best lights that are legal for the mini
I assume h4 - with relays & good battery voltage / charging
I will be looking as my sealed beams aren't IVA compliant apparently :o(
#5 JustJack
JustJack
  • 87 posts
Posted 24 December 2012 - 08:51 PM
That does sound better ye lol
so no ballast is needed ?
#6 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 24 December 2012 - 10:32 PM
Unless you've got some rediculous voltage drop going on it should be like blackpool illuminations with that many lights. How are they wired?
#7 electricjim
electricjim
  • 237 posts
  • Local Club: WSMOC
Posted 26 December 2012 - 09:36 PM
ring max H4 bulbs 100% zenon gassed bulbs just fit like any other H4 but are much brighter with a whiter light
http://www.ringautom...l.asp?prod=2055
Basically the difference is my dim dip as now as bright as my sealed beams used to be when properly on
#8 JustJack
JustJack
  • 87 posts
Posted 29 December 2012 - 01:19 PM
Luke, i mean just the headlights i think they are just the old standard lights when i have the spot lights on it is miles better but makes the headlights look pathetic
The spots i wired myself, but the original lights i can only presume they are wired how they are supposed to be untill i take them off and have a look,
maybe it just needs a modern bulb as jim suggests?
