Over Sill Normal Sill
Posted 20 December 2012 - 09:39 PM
Cheers james
Posted 20 December 2012 - 09:42 PM
Posted 20 December 2012 - 09:44 PM
Hi guys.... Maybe a stupid question but what's the difference between over sills and normal sills.... Just thought it would be a good idea to explain for those who don't know...;)
Cheers james
The Original sills (well, exept the VERY early ones) had vents in them, to let moisture out.
An over sill is also called a 'wide sill'. It is exactly that. It is wider and the vents do not exist. It is called an oversill because it is used to bodge over the original sills to get it through an MOT... or look good when selling.
Oversills are a big no-no. If all rot is removed before fitting they aren't as bad, but moisture always gets inside the sill area and they will rot from the inside out.
Genuine sills filled with waxoil will last for ever.
Posted 20 December 2012 - 09:45 PM
Cheers James
Posted 20 December 2012 - 09:47 PM
Cheers james
Posted 20 December 2012 - 09:50 PM
You can clearly see when buying that the 'vented' type have the vents. The oversills just have 6 'bulges' in them but aren's open
Edited by JustSteve, 20 December 2012 - 09:52 PM.
Posted 20 December 2012 - 09:51 PM
Posted 20 December 2012 - 09:52 PM
Posted 20 December 2012 - 10:04 PM
Genuine outer sill panels are about £20-25 and fit alot easier. where as a £10 non genuine sill will need a bit of jiffling to get it to fit neatly but will still fit.
Edited by KLMOC, 20 December 2012 - 10:04 PM.
Posted 21 December 2012 - 06:33 AM
Cheers james
Posted 21 December 2012 - 08:22 AM
Posted 21 December 2012 - 04:59 PM
Cheers james
Posted 21 December 2012 - 07:29 PM
I would recommend m machine short sills or if you can afford them Heritage short sills.
I fitted non gen sills to Project Erm and they fitted ok but when i bought a pair off M machine for Project Paddy the difference in metal thickness was very noticeable.
I would also recommend if you buy non gen sills then you will need to remove the dull grey paint they use on them. This will wipe off with thinners. M machine do not coat theirs so will need to be etch primed and then either zinc rich primer and paint or paint of your choice. Heritage have a very good E coat and will still need to be painted.
