Yale M69 Car / Van Security Dead Locks
8 replies to this topic
#1 mab01uk
mab01uk
  • 12,413 posts
Posted 16 December 2012 - 07:12 PM
When my classic Mini's were used as daily drivers I always used to fit Yale M69 Car/Van Security Deadlocks to both doors (half way down) and the boot, (as did companies like Wood & Pickett to their expensive Mini conversions). They were easier to fit to sliding window doors but could also be fitted into later winding window doors if you were careful to avoid interfering too much with the glass drop area/channels.
I can take some pictures of mine if anyone is interested.
Originally designed by Yale, the ‘M69’ is well-known within the security industry, where it is used to provide additional protection for motor vehicle doors. There are five lengths of lock cylinder to suit different door thicknesses, fitting into LH and RH standard cases. This lock was once fitted as original equipment to Rolls Royces.
  • Operating bolt throws into striker in door post, and is held positively by action of lock cylinder.
  • Key is turned through 360° to throw and withdraw deadbolt. Keys can be withdrawn in either mode. Bolt withdraws fully flush into case.
  • With components separated, case is sunk into door-edge, mortice fashion. Cylinder is inserted through aperture cut in door panel and is engaged into top face of case. It is then screwed fully into position using two holes in lock face. Finally, set-screw on flange is tightened, and pegs may be driven into face to seal fixing holes. Striker is fitted to door-post, and a trimescutcheon is provided.
  • Brass pin-tumbler lock with up to 1000 combinations. Unshuttered. Brass keys, nickel plated in ‘SX’ series
  • Chromium-plated throughout.
  • Lock and cylinder are brass, case is zinc diecast with steel cover plate and brass extruded bolt. Steel striker and escutcheon.
  • Standard key cylinder
  • Vehicle Security Locks:-
        https://advancedvehi...sical-security/
Edited by mab01uk, 14 December 2022 - 07:30 PM.
#2 Mattl
Mattl
  • 588 posts
Posted 16 December 2012 - 10:12 PM
I would be interested to see what these look like fitted :)
#3 mab01uk
mab01uk
  • 12,413 posts
Posted 17 December 2012 - 07:41 PM
OK, I will try to get some pictures of mine fitted and post them up in the next few days.
#4 Mattl
Mattl
  • 588 posts
Posted 17 December 2012 - 08:24 PM
Im surprised more people havent shown interest!?!
#5 mab01uk
mab01uk
  • 12,413 posts
Posted 21 August 2013 - 10:30 PM
Mk 1 & 2 Mini Doors fitted with Yale M69 Security Deadlocks -
Photos: Nevsmini
Edited by mab01uk, 21 August 2013 - 10:30 PM.
#6 JacckKirk
JacckKirk
  • 889 posts
Posted 21 August 2013 - 11:12 PM
Any idea how to fit these on doors with wind up windows
#7 Nick '91
Nick '91
  • 631 posts
Posted 22 August 2013 - 08:16 PM
Guessing you could swap it so the deadlock sits in the rear 1/4?
#8 mab01uk
mab01uk
  • 12,413 posts
Posted 28 August 2013 - 11:21 PM
I have fitted them to several Mk3 doors over the years.......you have to mount the lock upside down in the door so the lock mortice goes into a small slot cut in the pillar, where it curves out very close to the door frame. The window guide channel inside the door also needs a slot drilled/cut to clear the lock body but without interfering with the winding window glass when it drops down. Difficult to explain without photos but it can be done with careful measurement.....or practice on an old rusted door.
Or as said above you could maybe swap it so the deadlock sits in the rear 1/4?
Edited by mab01uk, 28 August 2013 - 11:24 PM.
#9 mab01uk
mab01uk
  • 12,413 posts
Posted 17 February 2016 - 08:23 AM
As mentioned the 'Disklok' came out best in tests of mechanical anti-theft devices by AutoExpress magazine:-
http://www.ovat.be/A...AutoExpress.pdf.
