Duplex Chain Tensioner Needed Or Not?
5 replies to this topic
#1 sam7
sam7
  • 165 posts
Posted 14 December 2012 - 08:46 PM
hi,
i have a 1380 engine with a twin duplex chain, but it never had a tensioner fitted, so was just reading through a engine project and the guy had the same set up as me. and he had fitted a tensioner.
are tensioners needed with a duplex chain??
funny thing is, i asked mini spares before fitting back together and fitting the engine back in. and they told me its not needed but now i kind of doubting it.
what do u guys think??? is it needed??
#2 Tupers
Tupers
  • 4,143 posts
Posted 14 December 2012 - 08:58 PM
You don't have to have one but keeping the chain tight will make it last much longer.
#3 sledgehammer
sledgehammer
  • 3,098 posts
Posted 14 December 2012 - 08:59 PM
I don't think they need one as the chain won't stretch as much -
but I'm sure they could be fitted if you can find a big enough chain slipper / tensioner foot
#4 sam7
sam7
  • 165 posts
Posted 14 December 2012 - 09:02 PM
cool, thanks for the help. i had one from a old engine and ur correct it wasnt wide enough to fit both chains on.
chhers guys
#5 Cooperman
  • 23,276 posts
Posted 14 December 2012 - 09:25 PM
The Duplex chain was originally fitted to the Mk.1 Cooper 'S' and it didn't have a tensioner.
On high-revving engines the tensioner can break up when revved high as the pad does not sit right across the chain but just bears on the chain centre. I've had engines to sort where the pad has completely broken up, but these were rally engines revved to around 7000 rpm. For engines kept below about 6000 rpm a tensioner could be OK, although it's not really necessary.
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 14 December 2012 - 09:42 PM
As cooperman said really. Only use one if it's a mild engine and you really are that fussed about the tiny amount of noise they reduce. The chain should never reach the condition that they are needed
I'm pretty sure most people keep them off. I won't be using one on my current engine build.
