Stalling When Letting Off Throttle
Posted 10 December 2012 - 10:53 PM
I have had this problem with my car for a while now and its starting to annoy me so thought I would ask.
Basically whenever I let off the throttle, the revs drop well below the normal idle speed (below 4-500), then gradually pick back up again (up to 20 seconds normally), but sometimes they drop right off and the car stalls, obviously this can cause some problems when driving haha
So what do you think could be causing the problem?
I'm running a HS4 carb, the idle speed is ok (900-1000ish), there is oil in the dashpot (20W50) and the car starts fine and drives fine on throttle, its just when letting off the throttle that I get problems.
Cheers,
Jake
Posted 10 December 2012 - 11:37 PM
Posted 11 December 2012 - 12:31 AM
Posted 11 December 2012 - 02:54 AM
Posted 11 December 2012 - 08:20 AM
I had the same problem not so long ago with my mini.
Turns out my car ran far better with the piston damper loosened off a bit.
After taking the piston damper out it was clear that an engine oil was used.
I changed the oil for a much lighter oil (similar to the classic haynes everyman)
Oh and make sure its filled correctly, the volume of oil should be about the same as the volume of the barrel on the end of the piston damper.
After doing so and refitting the piston damper mine didn't have the problem, may work for you?
I guess with a lighter oil the piston is able to move more free..
Anyway I won't be using anything but a light oil from now on, it seems much better
Posted 11 December 2012 - 10:39 AM
Why is it people use engine oils such as 20w50 in their dashpot?
Really depends on the engine and its spec. A standard engine would work better with the normal "lighter" SU oil. Where as a more tuned engine, like mine, has worked with 20w50 better. All depends on the engine, so no one solution fits all. same with changing the spring in the dash pot that will have an effect as well. I think you can even change the piston for a different damping rate!
But you are right, its worth a try at least, as well as checking or any air leaks.
Edited by freshairmini, 11 December 2012 - 10:40 AM.
Posted 11 December 2012 - 01:44 PM
The thing that makes me think its not a vacuum leak is that after a while it idles fine, and when driven lightly it idles fine too, but when accelerating then letting off the revs drop really low - suggesting its the piston/ piston related.
And as far as I can tell the mixture is ok, but with the recent cold weather maybe a flat or so richer would help?
I might take the dashpot off later and give it a clean as well just in case, then put some nice clean oil in there.
Cheers,
Jake
Posted 11 December 2012 - 01:54 PM
Posted 11 December 2012 - 04:35 PM
Posted 11 December 2012 - 09:19 PM
Tried cleaning the dashpot and putting more oil in - didnt help
The old 'wd-40-around-the-inlet-manifold' trick didnt seem to find any vacuum leaks there
The breather hose from the engine to carb seems to be causing the problem, as when I pinch it the idle speed rises, and there is no drop after revving, and it didn't seem to matter what part of the hose I pinched - same results. Which indicates a leak where it joins the breather, but the hose seems fine there and is still connected fine. Also taking the oil filler cap off seemed to affect the idling as well.
The plot thickens...
Posted 11 December 2012 - 09:44 PM
Posted 11 December 2012 - 11:33 PM
IMO it depends on your driving style to a degree as to what suits you. My current Mini seems to be running on ATF, although it is purple in colour (could it be specific dashpot oil?) I have to say, whatever it is (it seems similar in viscosity to ATF) it does shift very well IMO for a stock 998.
Posted 12 December 2012 - 03:00 AM
Rover specified engine oil in the dashpot, so it's the best starting point. It should only effect the mixture under acceleration (like the accelerator pump on Webers etc). The thicker the oil; the slower the piston rises ; the faster the airflow across the jet; the greater the Bernoulli effect; the faster petrol flows; the richer the mixture.
