Now am I right in thinking the pin needs to be pushed forward to get the arm out?
If so this is where i'm strugging because it will not budge.............
Any one had this problem?
By the way the shaft spins freely............
Posted 10 December 2012 - 10:10 PM
Posted 11 December 2012 - 12:19 AM
Posted 13 December 2012 - 01:24 PM
With my upper arm pin I removed the nut from the rear end of the pin and used a flat head screwdriver along with a hammer to pry the pin out by the lock plate, sounds a bit brutal but it didnt damage anything :) they are a bugger to get out with almost zero clearance in there..
Posted 13 December 2012 - 02:23 PM
Posted 13 December 2012 - 02:24 PM
Posted 13 December 2012 - 02:53 PM
Posted 13 December 2012 - 04:40 PM
Have you still got the hub attatched to the arm?
Has the thickwasher come out with the locking plate too?
Under the lock plate you removed is a large thrust washer. By the look of things, it may be rusted in place. Spray it with some rust penetrant and give it time to soak in. Reinstall the nut on the other end, leaving space between the nut and the frame. Then take your crow bar and carefully apply pressure between the nut and the foot well. It should dislodge the washer at the other end.
Edited by toplessmini, 13 December 2012 - 04:41 PM.
Posted 13 December 2012 - 04:53 PM
