Windscreen Demister Connection Problem
19 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 06 December 2012 - 06:45 PM
Yes, you can remove the intake duct above the drivers feed so the heater recirculates air from inside the car. Just make sure that you blank off the inlet stub properly, or you will have cold air at your feet. You will want to leave the under-wing duct and airbox in place so that the cold vent can still deliver fresh air from ahead of the engine when required. The stub which the duct inside the car fits to is the larger outlet on the airbox, the smaller one on top feeds the vent.
#17 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 06 December 2012 - 06:48 PM
Ref to what Tiger rightly says about your dash vents, I've blanked mine off hence didn't need the intakes anymore :)
#18 Scoop77
Scoop77
  • 508 posts
Posted 06 December 2012 - 07:08 PM
So just to clarify, blank off the inlet hole on the right hand side of the footwell and the intake on the blower unit itself? If so where does the unit get its air from?
#19 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 06 December 2012 - 07:10 PM
Blank off footwell hole to outside, leave blower hole :)
#20 Scoop77
Scoop77
  • 508 posts
Posted 06 December 2012 - 07:13 PM
Top man. Will give it go then.
Cheers.
