Mk1 Earth Scorcher
#61
Posted 16 February 2008 - 10:35 PM
#62
Posted 16 February 2008 - 10:36 PM
Hi nice mini you got there.
#63
Posted 16 February 2008 - 11:08 PM
This is going to be one awesome vee-hicle
#64
Posted 18 February 2008 - 12:48 AM
To keep the momentum up, I spent some time this evening rebuilding my axles with new CVs and Pot joints from Minispares.
I cant believe how good that shell is !! Roofless was a virtually brand new shell when I got it and it had a lot more corrosion damage than that.
Edited by Monte Busa, 18 February 2008 - 12:50 AM.
#65
Posted 21 February 2008 - 12:57 AM
The size of the wheel at 12.6 inches diameter (320 mm) is about what I wanted, and was the right price as they were on clearnace at AIM USA for a little more than the equivalent on 60 Pounds.
The Dash is great too, as not only is it a direct plug and play to the stock R1 harness, it has dual modes of operation - one for "street", with odometer, speed, RPM, Fuel Level, etc, but a "race" mode where you can log lap times at track days with the included beacon as well as set alarms for critical functions (oil temp, water temp, oil pressure, etc).
Both modes display gear position and have sequential shift lights- great stuff!
This is what the dash looks all lit up:
#66
Posted 03 March 2008 - 02:27 AM
Cheers,
Aric
#67
Posted 17 March 2008 - 12:23 PM
#68
Posted 17 March 2008 - 07:57 PM
Dam they are sexy! The centre locks look like large nipples with piercings!
#69
Posted 26 March 2008 - 10:12 PM
Looks like this is pannin out to be an amazin car
#70
Posted 28 March 2008 - 01:02 AM
i love the clocks in the steerin wheels and love the senter lock wheels.
#71
Posted 01 April 2008 - 11:54 PM
I used Eastwood for the Chassis Black / Rust Encapsulator / Rust Converter paint system for the backing plates and hubs, as well as for teh zinc plating of the handbrake cable backing brackets and actuator arms, having used one of their vibratory tumblers to help clean the parts prior to bringing elbow greae to bear to get the last bits of scale and rust off prior to plating or paint.
Edited by Monte Busa, 02 April 2008 - 12:41 AM.
#72
Posted 02 April 2008 - 01:10 AM
#73
Posted 02 April 2008 - 01:39 AM
The Mini is small, but that may be stretching it a bit
when this mini's finished it really ought to go in a glass box - too good to get dirty !
#74
Posted 10 April 2008 - 05:01 PM
And test fit the wheels / tires....
#75
Posted 11 April 2008 - 10:07 PM
