Mk1 Earth Scorcher
#241
Posted 10 January 2009 - 01:07 AM
J
#242
Posted 10 January 2009 - 04:36 PM
So have you had minworld or minimag in a bidding war for exclusive rights to feature this car yet?
J
#243
Posted 14 January 2009 - 10:50 AM
OK Pro-Mo owners - got a question and some thoughts for you:
...after driving my car a few times now, I am wondering if the amount of front wheelspin I am seeing under acceration is typical - don't get me wring, it's great fun, and I'd much rather have power to spare, but I guess I expected a bit more grip with the Quaife LSD and the sticky A032s (albeit on 10s). Now it has been in the 40degF range outside, so a bit on the cold side, so this probably isn't helpign things...but...
The thing will willingly light up in 1st and 2nd gear, and in third it's still clawing for traction, hunting all over the road under acceleration.
I'd love to hear your experiences...
If the tyre is not flat on the road but only a small point is touching it, this would result in less grip. i dont know know how much camber you have on the front wheels? if you would bring it back to 0 camber this could help your traction. also allignment in (parallel to the rear wheels) would help.
#244
Posted 14 January 2009 - 10:51 AM
#245
Posted 14 January 2009 - 12:31 PM
I think a main problem is your 10" wheels, i was running 12's and it wasnt horrific, Also i had a steel front end which got some more weight over the front. which is much needed.
#246
Posted 09 February 2009 - 01:40 AM
mine used to spin up obsessively, problem is the Quaife ATB isnt as good as a normal LSD i think, its much better for drivability, but for straight line death i think it allows too much. Depends what you want it for though.
#247
Posted 09 February 2009 - 02:17 PM
I have my speedo calibrated and its spot on and I am getting around 120-125mph. Before I was only getting to around 100 so the differant ratios make a big differance dont they.
Ill have to check my teeth to see what ive got when it comes back from the paint shop to compare as we both have 10" wheels.
I changed to the 18t output sprocket I got from Phil (thanks!) from the 17t today (it was actually close to 50degF today - unheard of in Michigan in February) - what a difference! Now the car almost bogs down - gotta keep the revs up now...I think i like this better but I will have to experiment some more. The good thing is it only takes ~5 minutes to swap out the sprocket - you could do it between track day sessions easily.
#248
Posted 10 February 2009 - 02:05 AM
#249
Posted 22 May 2009 - 02:03 PM
#250
Posted 22 May 2009 - 09:48 PM
lower tire pressures help also, even with my 14's
#251
Posted 02 June 2009 - 05:03 PM
Speaking of which, here are some pictures and the first of three videos I've compiled.
This one is from my buddy's RX-8 following me: http://www.youtube.c...re=channel_page
The next two I'll post in the next day or so, both in-car from different vantage pts.
The track day went great with no technical issues whatsoever, and huge interest in the car. We had 5 sessions of 8 to 10 laps each, and between sessions (4 groups, in rotation) I barely had enough time to eat a hotdog for lunch. There were typically 5 or so people around the car asking questions before I took my helmet off. I even got some interest from one of the local Newspaper motorsports columnists for a web feature he's doing. I gave a short video interview and did a in-car film for the photographer for the feature as well. It was pretty cool considering my competition for attention included a new Ford GT, two Elises, a number of GT-class race cars, Formula Fords, a genuine S3 Lotus 7, a Lotus Ford Cortina racer, and a bunch of tricked out STis and EVOs
On-trailer views in my driveway, the morning of the event:
Detroit News Interview for feature column
A pic of the tire wear after the event - these tires will last forever at this rate!
Edited by Monte Busa, 02 June 2009 - 05:07 PM.
#252
Posted 02 June 2009 - 06:50 PM
http://apps.detnews.....php?blogid=408
and the front cover pic blown up for posterity!
#253
Posted 03 June 2009 - 03:27 PM
Chase cam:
In-car:
On-windshield:
#254
Posted 03 June 2009 - 04:41 PM
Tell us more about how the car did on-track. It certainly looks quick. How was the handling and braking? Was the car understeering much?
#255
Posted 03 June 2009 - 05:06 PM
As far as handling, the car was very neutral, and could be steered with the rear end with a little opposite lock, especially with a dab of brakes to get it loose - it did hop around a bit on teh back though (see below). There was a bit of torquesteer on acceleration, but nothing more than what you'd get in any other high powered mini with similar wheels offset / large scrub radius.
I'm currently running 2.0deg negative camber on the front and 4deg caster and 0 toe, with 0.8deg negative camber, on the rear with 1/8" toe in for high speed stability. The GAZ coilovers are set for full stiff on the rear and mostly soft on teh front. I'm going to probably take a bit of the toe in out of the rear, and maybe raise the ride height 1/2 inch or so to see if I can get it to hop less around corners...next steps after than would be less camber and / or a rear antiroll bar...
Oh, and the braking was spot on - no fade and I could outbrake almost everything out there - the thing will really stand on it's nose. I'm running 8.4" vented discs, KAD 4 pots and EBC Greenstuff in front, Minifins in back. KAD bias box, with in-cockpit adjustability. The bias is set up similarly to how Sollis reccomends in his Mini race book to where I can barely (with a lot of muscle) turn the rear tires by hand while up on jackstands with full brake pedal pressure- fine adjustments from that pt using the bias adjuster
Good stuff!
Edited by Monte Busa, 03 June 2009 - 06:23 PM.
