Grille and bonnet installed, as well as arches and arch / body trim.
Currently working on finishing the door cards and door checks, and final fitting of the dash.
last is wiring, which I'm about 25% through with.
The only thing that will remain then before the beastie is done is to fit the exhaust system, which will involve a bit of bracket fab due tu using the ally beam axle vs the rear subframe.
