Weird One - Bonnet Wont Close!
11 replies to this topic
#1 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 01 December 2012 - 08:11 PM
As title really!
It never has closed but with MOT approaching it should do really haha ;)
Its either the spring bit on the bonnet or the latch on the front panel and I cannot tell for the life of me which is at fault
Anyone hazard a guess?
I got a gut feeling its the bonnet just not locking properly but who knows
#2 giner88
giner88
  • 914 posts
Posted 01 December 2012 - 08:14 PM
this happens with mine, if its got the internal handle sum times i have to push the handle forward (inside the car) really hard to get the catch to work. worth a try as it cost nothing
#3 conlad
conlad
  • 2,054 posts
Posted 01 December 2012 - 08:15 PM
Sorry should of said its external release
Will have another look tomorrow but I had my fat mate sit on the bonnet and still no luck
#4 giner88
giner88
  • 914 posts
Posted 01 December 2012 - 08:18 PM
hahaha fair enough. could just try lots of lube and get a screw driver and keep moving the catch back n forth to losen it up a little. may help
#5 conlad
conlad
  • 2,054 posts
Posted 01 December 2012 - 08:21 PM
Ey ey ey steady pal! hahaha ;D
Will give it a go, see what happens
I think it might be the spring bit on the bonnet :goaway:
#6 Scorp
Scorp
  • 319 posts
Posted 01 December 2012 - 08:23 PM
On mine i chopped some of the spring off to shorten it so it was tighter and then job was a gudden'
#7 conlad
conlad
  • 2,054 posts
Posted 01 December 2012 - 08:24 PM
Hmm good idea
I can puch the bonnet all the way down to the front panel no problem so there's obviously something not catching as it should
#8 Alex_B
Alex_B
  • 4,573 posts
Posted 01 December 2012 - 08:37 PM
Flat headed screw driver and wind back the pin on the bonnet catch so its lower and it should catch on the latch
#9 herdy
herdy
  • 377 posts
  • Local Club: Notts about minis
Posted 02 December 2012 - 05:35 PM
I had some trouble with mine a while back, I found that taking the mechanism off, giving it all a good grease up and bang it back on.
#10 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 02 December 2012 - 06:10 PM
This happened with mine - and it was a combination of both. The latch that held it in place was dodgy, and slamming the bonnet shut screwed up the spring. It hasn't shut properly for 3 years but now it will be fixed with a new bonnet!
#11 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 02 December 2012 - 06:16 PM
me too! where the spring is located on the bonnet is a welded bit of metal- well mine split the weld!
#12 WillRunci
WillRunci
    The night sausage
  • 266 posts
  • Local Club: RAF Mini Club
Posted 02 December 2012 - 06:58 PM
had the same with mine, all i had to do was bend the angle of the latch a little and its fine now.
